drivinhardz06 Posted May 22, 2009 Share Posted May 22, 2009 I have looked at the rule book and talked to another friend about this. If I am reading the rules correctly, there is a +2 penalty for caliper change but no place to put any points for rotor on a classification sheet. Rules read "any rotor" basically. (cooling ducts, etc are free obviously) So if I am reading this right, one could retain the stock rotors on the car and place a pair of $300 low end aftermarket calipers on the front of the car and take 2 pts, and you could take the same 2 pt hit putting @ $6k kit on the car w/ 4 high end aftermarket calipers @ 4 corners, and run 2" larger 2 pc rotors front and rear? IE, ANY brake upgrade hardware (rotor/caliper/caliper mounting bracket) is a +2 pt penalty? Is this correct? Quote Link to comment Share on other sites More sharing options...
Trevor57 Posted May 22, 2009 Share Posted May 22, 2009 Thats usually the case. I think dampers are the only area that has a dollar amount attached to it. Quote Link to comment Share on other sites More sharing options...
MRuth Posted May 22, 2009 Share Posted May 22, 2009 Rotors and pads are free. Only a caliper upgrade "Suspension/Brakes/Chassis: 24) Non-OEM brake calipers +2" Quote Link to comment Share on other sites More sharing options...
mbuskuhl Posted May 22, 2009 Share Posted May 22, 2009 You can also spend $1000+ on 2 piece rotors and take +0 You can also spend $0 and use stock calipers, but that did not come on the base model and take + 2 Ask me how I know. Rules are interesting, aren't they? Quote Link to comment Share on other sites More sharing options...
