Am I adding the points up right?
mrhongkongwong
2003 Mazdaspeed Protege
Mazda Mazdaspeed Protegé (Turbo) TTF** 2843
+14 and two (2) ** denotes a 14 point initial assessment that is added to the total number of modification
points to determine the final competition class.
+5 FORCED INDUCTION VEHICLES will add an additional five (+5) points to the total
number of modification points to determine the final competition class.
Mazdaspeed Protege comes with a turbo stock
+10 Aftermarket computer system (any non-OEM “stand-alone” or “piggyback”):
Forced Induction Piggyback System
+7 DOT-approved R-compound tires with a UTQG treadwear rating of 50 to 130 (ex. Kumho
V700, Michelin Pilot Sport Cup, Nitto NT01, Pirelli PZero Corsa, Toyo R888,
Yokahama A048, etc.—note: see exception below in 3)) +7
Plan on running Toyo R888
+4 TTA: 295 mm, TTB: 265mm, TTC: 255mm, TTD: 245mm, TTE: 235mm,
TTF: 215mm, TTG: 195mm, TTH: 175mm
Equal to or greater than: 10mm +1, 20mm +430mm +7, 40mm +10, 50mm +13,
60mm +16, 70mm +19, 80mm +22, 90mm +25, 100mm +28, 110mm +31, 120mm +34, etc.
Plan on running 235/40/17 R888
+1 Replacement pulleys (other than for supercharger) +1
Crank Shaft Pulley
+1 Modification of the OEM air intake/box, air filter location, air piping to the turbo/
supercharger/intercooler/throttle body/carburetor, or hood/fascia/fender air inlet(s) +1
Running a Hard Pipe instead of the Stock Plastic one
+1 Non-OEM, modified/ported, or deleted intake manifold: 4 cyl. +1, 6cyl. +2, 8 cyl. +3,
12A &13B rotary +2, all other rotary +3
Aftermarket Intake Manifold
+2 Non-OEM or modified exhaust system downstream from the header, exhaust
manifold, or turbo.
Full Turbo Back System from the turbo
+1 Non-OEM or modified exhaust piping, resonators, or mufflers downstream from the OEM
catalytic converter(s) locations(s) +1
Cat-back Exhaust
+1 Removal, upgrade, or modification of catalytic converter(s). +1
No Cats
+3 Upgrade number of forward gears in transmission or altered gear ratios +3
Planning on putting different gear ratios
+1 Changed or modified limited slip differential (or welded/locked OEM LSD) +1
Stock had a viscous diff, now I have a quaife
+3 Non-OEM or modified/re-valved shocks/struts/dampers +3
Koni Strut Inserts
+2 Non-OEM or modified coil springs, leaf springs/spacers/brackets, or torsion bars +2
2.5" Race Springs
+2 Add, replace, remove, or modify anti-roll bars (“sway” bars—front, rear, or both—may have
spherical joints on the end links without additional points assessment) +2
3 Piece Splined Swaybar
This will put me at +58 Points which is Plus Two Classes.
I'd like to confirm that I would be in TTD
+4 Replace or modify control arms (other than plates, shims, slots, or eccentric bolts/bushings
for simple camber/caster adjustment only)(may have spherical/metallic joint(s) for
the connection to the spindle/knuckle) +4
Camber Plates
I forgot about these, so with his added, this should put in the Three Class so that means I'm in TTC unless I downgrade some of my modifications?
+4 Replace or modify control arms (other than plates, shims, slots, or eccentric bolts/bushings for simple camber/caster adjustment only)(may have spherical/metallic joint(s) for the connection to the spindle/knuckle) +4
You shouldn't take points for the caster/camber plates, as they are freebies. That will save you +4 if you have not replaced or modified the control arms.
Mark
Crank Shaft Pulley
manifold, or turbo.
Cat-back Exhaust It's +2 here, because you have deleted the oem cat.
No Cats
Planning on putting different gear ratiosThis only counts for individual gears, not the final drive.
Koni Strut Inserts
2.5" Race Springs
What region are you in? It looks like the midwest has a shortage of D cars.
shortage is better than none - TX region doesn't have any yet
TTD is lonely down here in Florida as well. At the most, we'll have 2 cars, but I'm usually the lone gunman.
Mark
You should just run TTA.
Next thing I know you'll be trying to convince me to run my underpowered v6 mustang in TTA, when its barely TTE.
I take it back - it was right at TTF +29 points, 1 more point it would be TTE
Hello All!!!
Maybe I don't understand the ins and outs...Why would you add +5 for the turbo (unless it's an upgrade)since the TTF** should take the stock turbo into account?
  • National Staff
Hello All!!!
New rule this year--all forced induction (that is not re-classed by Dyno) takes an extra +5 points. We added this when we made simple ECU reflashes and chips free this past year.
Also, guys, while it is nice that you are trying to help him class the car, I can't tell you how many times we have had problems with cars being classed over the Internet, or even at the track without actually inspecting the car. As it states in the rules, if a driver has questions, he should bring them directly to his regional TT Director.
