944 Cup Car -- Under $7k
944 cup
1983 944. 2.5L 8Valve. 944 Cup legal with PCA and SCCA log books. Ready for NASA log book.
400 lb coil overs front, 30 mm T-bars rear,
Koni Sports struts in frt with ride height adjustable perches,
New Delrin bushings front & rear.
Lowered, corner weighted and balanced,
25mm front sway bar, 18mm adjustable Weltmeister rear sway bar,
PFC-97 pads front, Hawk Blue rear.
AC delete, Cat delete, throttle response cam, kill switch,
Stripped and painted interior, full cage, Kirkey driver seat with head restraints w/ 5 pt harness, window net,
Corbeau passenger seat, both w/ 5 point camlock belts.
Quick release Momo wheel, shift light, kill switch, 17' Longacre wide angle rearview mirror,
Fire suppressant system with interior and exterior activation trigger,
Cookie Cutter wheels
Adjustable camber plates,
K&N air filter
Parts Replaced:
Wheel bearings
Brake master cylinder
Starter
Fuel pressure regulator
Rack and pinion assembly and tie rods
Water pump update kit
Power steering pump
Fuel pump
Engine main and rod bearings
Piston rings
Ignition wire set
Clutch
Brake rotors
All belts
Distributor cap
Fuel injectors
Clutch master & slave cylinder
Sale price: $6800.
email Dave at [email protected]
  • 4 weeks later...
  • 3 weeks later...
  • 2 weeks later...
Why wouldn't this qualify for Spec 944? I dont know too much about the different class types.
Thanks!
Actually, based on the information listed, it should be legal for 944-SPEC.
  • 2 weeks later...
