codeblack Posted June 7, 2009 Share Posted June 7, 2009 Where can I find a tether to attach to my camcorder and harness bar I checked the rules and it doesn't state what type of strap it has to be. I'm assuming a nylon strap of some type would be OK can someone tell me what you use. Thanks Quote Link to comment Share on other sites More sharing options...
edhunter Posted June 8, 2009 Share Posted June 8, 2009 The strap on mine is just a 1" wide thin nylon strap, like what you'd find for a bicycle tiedown strap... The clasp is a lightweight spring clamshell type fastener (does that make sense?) Anyway, it's nothing heavy duty that's for sure... Quote Link to comment Share on other sites More sharing options...
99HOSS Posted June 8, 2009 Share Posted June 8, 2009 check out Chase Cam for accessories. Quote Link to comment Share on other sites More sharing options...
codeblack Posted June 13, 2009 Author Share Posted June 13, 2009 I'm a little confused. The tech inspection sheet for PDA, HPDE's states the strap is to be around the camera and the NASA rule book states tether from the harness bar to the camera. I guess I'll call PDA to confirm unless someone can set me straight. Quote Link to comment Share on other sites More sharing options...
soundguydave Posted June 15, 2009 Share Posted June 15, 2009 Basically, for NASA, they want to see two forms of retention: a screw/bolt from the vehicle to the camera as a primary mount, and a tether that will restrain the camera connected to the vehicle as a secondary form of retention. In a nutshell, if the camera mount fails in a crash, or other situation, the tether is there to keep the camera from becoming a projectile inside the car. Most common is a rollbar mount that clamps to the rollbar and has a thumbscrew to mount to the bottom of the camera (like a tripod mount), and a tether that wraps around the camera (through the handle) and cinches it to the rollbar. Headrest-based camera mounts are NOT legal with NASA. Quote Link to comment Share on other sites More sharing options...
gte024h Posted July 11, 2009 Share Posted July 11, 2009 Headrest-based camera mounts are NOT legal with NASA. That's odd... for all the NASA HPDE events I've been to my CruiseCam headrest mount passed tech without a blink. Perhaps they aren't legal in the racing classes? Quote Link to comment Share on other sites More sharing options...
jason Posted July 11, 2009 Share Posted July 11, 2009 Or you just got lucky. Quote Link to comment Share on other sites More sharing options...
Meat Posted July 12, 2009 Share Posted July 12, 2009 I've also used the CruiseCam mount without problems. What I was told was that it was fine as long as there was metal-on-metal contact and a tether was used. Quote Link to comment Share on other sites More sharing options...
sscguy Posted August 31, 2009 Share Posted August 31, 2009 I think the idea with illegality there is that you have a metal rod pointed generally at the driver's head/neck. In the event of an accident, who knows what could happen. That's my understanding at least. Quote Link to comment Share on other sites More sharing options...
