Yousko vaults to second place in the 2004 Championship!
Pete got in some late season racing with us and leap frogged into a strong second place, nudging Jason Wilberding into third and bumping Dylan Scott off the podium altogether.
Pete's efforts late in the Championship will earn him $300 towards TOYO TIRES!
Way to go, Pete!
2005 is going to be much closer in the points standings, with many more drivers coming up to speed!
Great Job Pete.
I should have the points updated in the next few days.
man....I didn't realize there was Toyo $$'s on the line!
I was talking to Dylan about it and we both thought there was only something for 1st place.
What is it for 3rd place?
Yep toyo bucks go through 3rd place for season championship.
Pete when from 4th to 2nd in points.
Final 2004 So cal Points standings are as follows....
1) Tim Comeau - 1340 pts - $600 Toyo bucks
2) Pete Yousko - 865 pts - $300 Toyo bucks
3) Jason Wilberding - 750 pts - $150 Toyo bucks
4) Dylan Scott - 680 pts
Full details found below.
http://members.rennlist.com/m758/2004-SoCal-Results.htm
Toyo Details
In addition to the rebate awards outlined above,[per race awards .ed] those classes that do spec. the Toyo Proxes RA1 as the only tire to be used will also be eligible for the following award:
2004 REGIONAL CLASS CHAMPIONSHIP
1st Place = 600 “Toyo Dollars” rebate certificate
2nd Place = 300 “Toyo Dollars” rebate certificate
3rd Place = 150 “Toyo Dollars” rebate certificate
There must be a minimum of five competitors participating in the regional class championship to qualify for the class championship rebate award.
2004 Saw 19 Drivers compete for points.
TOYO TIRES SoCal season points have been finalized as of today(11/22, thanks a ton to NASA Jim!). I've made a copy of the results and mailed it off to TOYO for a big paycheck!
Pete and Jason, please do the same. You don't need any form, there is none for the championship. I just highlighted my name, results, and stuck a post-it pad note on there with my address.
Congratulations, you guys!
