jjgrow Posted November 21, 2004 Share Posted November 21, 2004 I've had an intermittent starting problem that I think might be the solenoid. I was thinking it was my push-button starter switch but now I'm thinking its the solenoid. I went out to start the car today and had plenty of battery but the starter didn't turnover or click when I pushed the starter switch. There was, however, a noticeable 'drain' on the electrical system when I pushed the button which led me to believe the switch was working fine. I dropped down and 'jumped' the solenoid between the + and - posts which immediately began to crank the starter. Hopped back in and hit the starter button and the starter now cranks over. Could this be a failing solenoid or something else? Quote Link to comment Share on other sites More sharing options...
944-Spec#94 Posted November 22, 2004 Share Posted November 22, 2004 Bad solenoid. On my car I had to rig up some thing to connect the parts of the 84 944 harness with later 87 924 main engine harness when the connectors did nto match This cause a hot start problem that was caused by too thin wires going to the starter. Thus low volts and not enough to crank. Unless you have some funky wiring I guess the solenoid. Buy a rebuilt starter and swap yours out. 15 min job. 30 min if you could the beer after the job is done. Quote Link to comment Share on other sites More sharing options...
Tim Comeau Posted November 24, 2004 Share Posted November 24, 2004 Solenoid, hemmoroid, asteroid, fibroid.........we all have problems. Hope yours gets better. Quote Link to comment Share on other sites More sharing options...
944-spec#09 Posted December 1, 2004 Share Posted December 1, 2004 If you do replace the starter, get a late model one. It is considerably lighter than the early one. The late one fits all cars, not sure about the early one. Quote Link to comment Share on other sites More sharing options...
