FS: CSP prepared '91 Miata
Posted (edited)
SOLD
Mariner blue '91 Miata. ~155k miles on the chassis, ~110k miles on the full 1.8 liter drivetrain from a '95 R-package car. Never wrecked, ZERO rust, really nice bodied southern car. This car started life as a bone-stock B-package car, but the power steering was deleted (de-powered rack), cruise control deleted, and the power windows were yanked in favor of manual units. A/C is still intact (hey.. it's hot down here, okay?)
Now for the long read...
Engine
-'95 1.8 liter
- FM throttle body adapter
- FM coil-pack adapter
- FM EGR block-off plate
- FM throttle-cable adapter
- RX7 AFM
- Monsterflow intake w/K+N
- Header
- Mazdacomp cat-back w/test pipe
- Fidanza aluminum flywheel
Suspension/chassis
-full 1.8 drivetrain
-Torsen rear LSD
-1.8 transmission
-Delrin differential mount bushings
-Mazdacomp engine mounts
-S.S. clutch line
-Re-built and re-valved Bilstein sports shocks (valved for ~700# front, 400# rear spring rates)
-FCM coilovers with 450F 325R Eibach springs
-FCM upper shock mounts
-FCM bump stops
-Racing beat tubular front swaybar
-Advanced Autosports spherical swaybar endlinks
-Mazdacomp swaybar brackets
-949 Racing front lower chassis brace
-949 Racing rear lower chassis brace
-FM front upper shock tower brace
-R-package tie-rod ends
-15x7 et28 Rota Slipstreams w/ Falken Azenis
-Harddog Hardcore Hardtop Double-Diagonal roll bar
-FM form-fit high density rollbar padding w/black Vinyl cover
-De-power'd power steering rack
Brakes
-1.8 liter rotors/calipers
-949 Racing S.S. brake lines
-Carbotech Panther Plus pads
-'95 1.8 proportioning valve (not installed)
Body
-Mariner blue w/matching hardtop (no headliner or defrost model)
-all emblems shaved
-R-package front and rear lips
-R-package rear wing
-front tow hook
-Hella H4 headlights
-antenna deleted
Interior
-full '95 interior (dash + door panels) airbags deleted completely
-2x Momo Start seats on sliders
-2x 5-pt G-force cam-lock harnesses
-Momo Competition steering wheel w/Momo hub
-bolt-on steering wheel quick release
-Sola Luna shift knob
-Redline Goods blue stitched leather shift-boot
-Redline Goods blue stitched leather e-brake boot
-Panasonic cd/mp3 player
-6.5 door speakers
Other new parts (between 1k-4k miles old)
-timing belt
-water pump
-cam seals
-crank seal
-CAS o-ring
-valve cover gasket
-rear main seal
-accessory belts
-t-stat
-clutch + pressure plate, T.O. bearing, release bearing
-O2 sensor
-rubber shift boots
-rear caliper
-steering rack boots
-heater core hoses
ALL the suspension components are new (~1k miles on them) as are the brake lines, rotors, 1.8 swap parts, motor mounts, diff mounts, etc.
Paint is less than a year old. Not a show-car job; a couple small flaws, but still looks great and gets lots of compliments. The car has spent most of the last 2 years garaged.
All the car is lacking is a competitive alignment, and it is completely done. Get in, drive it anywhere. It's damn loud, but surprisingly comfortable.
Receipts from everything. Clean and clear title.
Only issues;
-there's some chipping paint on the driver's fender near the wheel lip
-rear main weeps a bit when the car is sitting for a while
-a/c needs a re-charge (Still works though. Barely.)
(pre-quick release)
Located in Charlotte, NC
-Adam
[email protected]
Price drop to $6300. New pictures coming soon as well.
