Airdams
Hi guys.
Just a quick question about you who have made you own front Airdams.
I'm looking at doing this myself but unsure of the type of material to use for it.
Could anyone specify some material to make these from.
Cheers
Tristan
  • 2 weeks later...
I used an alumalite sheet for the flat bottom section, and aluminum sheet metal for the front "dam" section. Your local sign shop should have the alumalite sheets as it's used to make large outdoor signs.
For airdams, plastic roll sheet from the circle track vendors is very popular - http://www.southwestspeed.com/?sec=view_part&id=3698
For a splitter, 3/8" multi ply cabinet grade plywood covered in fiberglass resin is common and much more durable than aluminum.
Not an HC, but here's a splitter/air dam made from the above components:
Awesome guys.
Thanks heaps for the help.
I'll look into those items you suggested.
Keep the replies coming
