1983 Porsche 944 race car and trailer For Sale
1983 Porsche 944 Race Car with newly rebuilt 1986 motor for sale with Carson lightweight trailer with tire rack and electric brakes with two sets of wheels (Fuchs and Phone Dials with Kuhmo Victoracers and New Toyo RA1 tires) and many spare parts (filters, spark plugs, brake pads, bumpers, hood, rear deck, passenger door, etc...).
Call or email Mike. 408-476-89 seven nine (I can email you photos)
Safety Equipment:
* Full Auto Power Bolt In Roll Cage with Door Bars Using Grade 8 Fasteners, Fully Padded
* 2.5 Pound Fire Extinquisher Mounted to Driver's Seat
* Kirkey Aluminum Driver's and not installed but available Passenger's Seats with Lumbar support
* Auto Power Seat Back Braces on Driver's and Passenger's Seats
* M&R Custom Made Window Net with Latch ans Link Hardware
* Custom Made Simpson Platinum Series SFI 16.1 Formula One Six Point Harnesses
* Steering Wheel Lock Removed per NASA Pro Racing Rules
* 36" 5 Panel Rear View Mirror
* Chrome Hood Pins
Engine:
* 1986 2.5L 4 Cylinder Engine 10.6:1 Compression Ratio ($5K Rebuilt by Don's Autowerks in Campbell with less than 50 miles on engine)
* Push start button and emergency cutoff switch
* Authothority Computer Chip Upgrade
* Adjustable Billet Aluminum Fuel Pressure Regulator
* Custom Exhaust Manifold Heat Shield
* Custom 2 1/2" Exhaust System with Catalytic Bypass Pipe
* Magnaflow Muffler
* Accusump 3 Quart Pressurized Oil Sump (removed but included with all hardware)
* AN Fittings and Stainless Steel Braided Hose 12AN from Sump to Engine
* Billet Aluminum Oil Filter with Removable Cartridges
* Custom Aluminum Airfilter Housing with K&N Cone Style Thru Flow Filter
* Cold Air Induction System 4"
* Custom Under Engine Aluminum Shield
Suspension:
* Lowered to Minimum Ride Height with 3" Ground Clearance at Lowest Point
* Koni Sport Adjustable Shocks and Struts
* 31mm Hollow Torsion Bars Rear
* Coil Over Front Struts with 450 Pound 2 1/2" Hypercoil Springs
* Racers Edge Billet Aluminum Adjustable Monoball Camber Plates
* Racers Edge Upper Spring Seats (Hats)
* Aluminum Front Strut Tower Brace
* Aluminum Front Control Arms with New Ball Joints
* Weitmeister Front Control Arm Bushings
* 30mm Hollow Front Sway Bar
* Racers Edge Delrin Front Sway Bar Bushings
* Sway Bar Brace
* 19mm Rear Adjustable Sway Bar
* Racers Edge Billet Aluminum Rear Sway Bar Carrier with Delrin Bushings
* Adjustable Heim End Rear Sway Bar Drop Links
* Weitmeister Spring Plate Bushings
* Adjustable Spring Plates
* Weitmeister Torsion Tube Carrier Bushings
* Weitmeister Torsion Tube Frame Mount Bushing
Rebuilt from previous race car with detailed pictures of equipment here:
http://www.detailingdynamics.com/carom0504.html" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
