I still use the factory gas tank like many of the HPDEers and racers we all see. I do have an issue with fuel sloshing around under a 1/2 tank, apparently my factory baffling is kind of crap.
While keeping car modification costs down, what is the best easiest to use fuel cell foam for a factory gas tank? I have about a 6" dia. hole to work with and would like to get a good bit of foam in there to help reduce my sloshing and constant worry of fuel starvation on track.
i know a fuel cell could be ideal, but without going down that pricey road, id like to try this first.
I've been pondering this as well. I think fuel cell foam you need to replace every few years? I've been thinking about making a metal baffle. That would be zero maintenance. I'm not sure about the design though. Maybe a type of screen would work as well, like in an oil pan.
