FS: PTC Mitsubishi Eclipse
FOR SALE: 1993 Mitsubishi Eclipse GSX road race car
This is a fully sorted car. I have successfully campaigned this car in Performance Touring C in NASA's Midwest Region in 2007 and 2008. It has garnered the Midwest PTC Championship both years. It is turnkey ready and is class legal. This has been a great car for me but I am looking at a different platform to run in a different series.
The particulars are below:
All-wheel drive
'93 shell
6 bolt motor
2940 lbs competition weight
193+ whp on 12 lbs boost
White interior and exterior with black roof
Currently raced on 93 octane pump gas
Oil changed and brakes bled between every race weekend
Remainder of fluids replaced between seasons
Complete race recaps, notes and dyno sheets available.
Engine:
Stock 2.0 liter DOHC motor with balance shafts removed. Was rebuilt at beginning of 2007 season. It has seen 8 race weekends.
Head is shaved
ARP head studs
16G turbo
Manual boost adjuster
Ported Exhaust manifold
3" downpipe
Custom open exhaust to rear
2G MAF
Apexi AFC controller (5 knob)
Aftermarket fuel injectors (size unknown)
Walbro 190 fuel pump
Magnecor 8.5 mm igintion wires
K&N air filter
Custom pipe between intercooler and throttle body with 1G BOV
Urethane motor/tranny mounts
relocated stainless turbo oil feed line
Earlier 1G oil cooler (fin-type)
Pentosin 5W-40 synthetic oil used
Drivetrain:
Stock 5 speed transaxle rebuilt at beginning of 2007 season
Archer Racing center diff
Short throw shift kit
ACT 2600 clutch
stainless cluth hydraulic line
Factory 3 bolt rear LSD
Red Line fluids used
Suspension:
'Muellerized' JIC dampers/coilovers with full race spring rates and camber plates
Offset poly bushings on front lower control arms
15/16" rear sway bar
Front strut bar (bolt-on)
Rear strut bar (weld-in)
Front camber -2.5
Rear camber -1.5
0 toe front and rear
Cross weighted at 50%
Momo steering wheel
Brakes:
Front calipers: Wilwood aluminum 4 pot
Front rotors: Wilwood 13" x 1.25"
Polymatrix H and B compounds front pads
Stock rear calipers with functioning hand brake
Metal Master rear pads
Adjustable rear brake bias
ABS removed
Brake master cylinder stiffening bracket
Stainless brake lines at corners
Pentosin Racing brake fluid used
Wheels/Tires:
4 Enkei RP03 Racing wheels 17x8.5 w/ 35 mm offset
4 used Toyo RA-1 235/40ZR17 (seen one weekend)
4 well used Toyo RA-1 235/40ZR17 (spares)
2 Hoosier R6 245/40ZR17 with a few heat cycles left
Miscellaneous:
Carbon fiber hood vent
Oil temp gauge
Volt meter
Boost gauge
Baffled gas tank with modified low fuel light
Interior gutted except for dash
HVAC functional
A/C removed
Race specific:
AMB transponder (installed on ignition)
Autopower 6 point bolt-in rollcage (SCCA and NASA legal)
G-Force Pro 5 point belts (3 years left)
G-Force drivers window net (3 years left)
right side head restraint (3 years left)
Sparco 2000 race seat (needs back brace)
2.5 fire bottle bolted to passenger floor
Wink mirror
Optima red top battery relocated to rear
Kill switch mounted on passenger side dash
Doors gutted and glass removed
hood relase cable removed; 2 hood pins installed
Hood gutted
Bumpers removed
Sunroof deleted via sheet metal and rivets
weld-in bung on downpipe for wide-band 02 sensor
intermediate driveshaft saftey wired
turbo safety wired
Spares:
complete rear including suspension, diff/driveshafts
K&N air filter
control arms
rear driveshaft
Hoses, belts, etc
2G MAF
Center diff
transaxle
Intake manifolds
fans
radiator
stock intercooler
spark plugs
etc...
This car has been very reliable. It has finished every race (16) it has started except at Mid-Ohio where it was hit on the first lap.
Issues/Concerns:
The bottom of the driver's side door is creased from an impact at the Nationals at
Mid-Ohio when a competitor spun in front of me. The car has no problem
passing the 50/50 rule but the crease is noticeable. I have a replacement door but it is red.
A repaint of the entire car with the new door is available for an additional price.
These cars are notorious for fuel starvation in high G left hand turns due the fuel pump being located so far left in the tank.
I have baffled the tank to address this but it has not completely cured the problem. Because of the baffle the fuel level
gauge is no longer functioning but I modified the fuel level low light to illuminate at 3/8 of a tank...before the light comes
on the car will not starve for fuel on left-handers.
Asking $7,000 or B/O
Please call Dave at 651-964-9011 if interested.
Negotiable:
18' ft open steel 2001 Falcon trailer w/tire rack
Delivery
Crew/Assistance for first event
Car is located near Minneapolis, MN
Pics available upon request (board attachment quota has been reached??)
