stevepoe Posted July 17, 2009 Posted July 17, 2009 story, bought this a few years back from Jeff at optima. Ran this in my Ai /cmc car for that couple years. decided to build a new s197 ai car and purchased another Mychron from Jeff for the new car thinking my old dash would go with the car. Pretty much parted my old car out and this is left. I'm running the new dash in my new car and really have no use for it. I have everthing that it came with when purchased new. extras that come with it are a extra temp sensor and a few exra lengths of cable. I was running oil temp and pressure and water temp. new pricing http://www.pegasusautoracing.com/pro...asp?RecId=5095 $849 http://cgi.ebay.com/ebaymotors/MyChr...QQcmdZViewItem $849 $550 with my extra sensors and cables. [email protected] Cincinnati Ohio MyChron3 Gold link: http://www.aimsports.com/products/m3...uto/index.html info:The MyChron3 Gold Auto is designed for racers who analyze their data on their PC. It is designed for multi-cylinder automotive and motorcycle racing. The MyChron3 Gold Auto has all of the features of the MyChron3 Plus Auto, with the addition of an internal lateral G sensor, more memory and up to 200Hz sampling and recording per channel. The lateral G sensor lets you create a map of the track when you download the data to your PC. In addition, the MyChron 3 Gold Auto has 4 fully configurable analog inputs: temperatures (thermocouples – thermoresistors), pressures (Oil – Fuel – Airbox), potentiometers, potentiometers (suspension travel – brake pedal displacement – throttle pedal displacement – steering angle – roll angle), Lambda sond, “on-board/stock” sensors, or custom made sensor configurations, gear position (either sampled from an “on-board” gear sensor or calculated from RPM and speed values), and lap times. The MyChron3 Gold Auto features a beautiful backlight display and built-in 200 Hz data logger. View the playback on screen or download the data to your PC via the high speed USB port. Use our powerful Race Studio 2 software to analyze the data on your PC. The MyChron3 Gold Auto comes with 8MB of memory, able to record hours of data on all inputs. __________________ Quote
