Legends21 Posted July 20, 2009 Posted July 20, 2009 Does anyone have a belly pan (lower tray) to fit an early 944? When I was at Lowes Motor speedway a couple of weeks ago, it seemed that the lack of a belly pan (along with the tall 5th gear) really impacted the top end speed . I have since rectified the gear issue; I now would like to solve the other problem. Thanks. Dale Ritchie Lexington, SC Quote
Spec944 #143 Posted July 20, 2009 Posted July 20, 2009 check with ApartAbove- I bought mine from him for a reasonable price. Not sure it helps with speed but it does seem to help with lowering water temps. Quote
944-Spec#94 Posted July 21, 2009 Posted July 21, 2009 you are also allowed to fab one that is roughly the same dimensions. Quote
Legends21 Posted July 21, 2009 Author Posted July 21, 2009 Could someone post pictures of a fabricated pan? What material did you use? Does it have holes or is it solid? Thanks in advance. Dale you are also allowed to fab one that is roughly the same dimensions. Quote
