almost heaven Posted July 27, 2009 Share Posted July 27, 2009 What's the difference in use between a 4-pole and a 6-pole battery disconnect switch? I need one for my SR20DET powered RX7. Thanks. Quote Link to comment Share on other sites More sharing options...
Legends21 Posted July 28, 2009 Share Posted July 28, 2009 What's the difference in use between a 4-pole and a 6-pole battery disconnect switch? I need one for my SR20DET powered RX7. Thanks. Generally, the 4 pole has two single pole disconnects that are ganged to open and close the connection together. The 6 pole has another set of contacts that are closed when the other two are open. The extra set of contacts for the 6 pole is normally used to shunt the Alternator output to ground through a load (resistor). Dale Quote Link to comment Share on other sites More sharing options...
