1995 Honda Civic HB PTC/H2 (Arizona)
1995 Honda Challenge Civic Hatchback (PTC/H2)
I just don’t have time to drive.. Needs a Good home!!
Maintained by UMS Tuning in Mesa Arizona
Safety Items
• Auto Power Cage that has been modified
• Sparco Evo Seat
• Gforce Center Net
• 2 nozzle Halon
• Gforce Side Net
• GGorce FIA Belts
• Sparco Race Wheel
• NRG Steering Wheel Release
• Sparco Safety Shut off Switch
Comfort items
• Pioneer Deck CD with 2 MBQuartz Speakers to jam to tunes to get jazzed before the race. (the car was a little light for PTC)
• Auto Meter Gauges, Oil Pressure, Oil Temp, Water Temp
• Strobes (Front Only)
• Fan Switch (Dual Fans)
• Working Turn Signals and Hazards
• Working Head lamps
• Blind Apex on Board Timer
Performance Items
• B16B CTR Motor (Fully Stock) (184 HP to the Wheels) (OBD2)
• CTR LSD Factory 4.4 Final Drive
• Fluidyne Radiator (ITR)
• Fluidyne Oil Cooler
• Greddy Remote Oil Filter Kit
• Big Carbon Fiber Password JDM Intake (Short Ram)
• New Injectors (Custom Jetted)
• New adjustable Fuel Pressure Regulator and Guage (B&M)
• New Fuel Pump (255 Walbro)
• New Gas Tank (Factory)
• Plugs and Wire(NGK)
• Hondata S300 in a P28 ECU
• Custom Magna Flow Exhaust, Hytech Knock-off Exhaust
• Centerforce Flywheel and Clutch
• CTR Short Shift
The timing belt, oil pump, and water pump were changed when the motor was swapped in.
Suspension
• PIC Fully Adjustable Coil Overs
• Ksport Camber Kit Rear
• Ksport Front Camber Kit
• Ksport Rear Toe Kit
• New outer tie rod ends (front)
• JDM ITR (23mm) Rear Sway Bar
• ASR Rear sub Frame brace
• 2 sets of Wheels
• Full Bushing Kit
Brakes and Wheels
• 15/16 Master Cylinder
• Extended Wheel Lugs
• New Wheel Bearings
• Honda CRV Front Brakes (4 lug Converted)
*Honda SI rear Disc Brakes
• Hawk Pads (Blues)
• Stainless Steel Braided Lines
• 2 Sets of Toyo Tires (One Set RA1- one Set R88 and Drag DR29s Wheels (Gun Metal) 15x7 4x100
This Car comes in at 2500 with me in the Car (180lb) - This is a Solid PTC/H2 Car.. I change the Fluids with Motul After each Weekend.
Price is $7999 OBO Race Ready and NASA Log Booked!
Hit me up with any questions
Jason Boles – [email protected]
  • 7 months later...
PRICE UPDATED!! $7999
I will take a TRADE on this for a Street Car, Motorcycles.. something with a Title..
Im not Racing anymore.. and frankly Im tired of Storing it!!.. Make me a good Trade and we can most likely get a deal going..
