dillehayd Posted July 31, 2009 Posted July 31, 2009 Time to part out the old race car. The motor was running very well when I got t-boned in the driver's door on track. It continued to run properly when I quit spinning. M52 from 1997 328. 115k miles on the ODO. S52B32 Cams professionally installed 4 angle valve job on head in 2007 Metal impeller water pump OBDII ECU flashed w/ AA software by Bimmerworld (twice, once before and once after dyno run) Harness provided as-is. Only thing cut was the fan stuff. Fresh oil pan gasket and RMS Not included: Accesories/brackets All intake parts (no plenum, no TB) Exhaust headers (stock headers can be provided if still available, +$50) Pressure plate, clutch, flywheel (can provide used stock parts from S52, +$100) Thermostat housing and thermostat Engine dyno'd at 220rwhp 190 tq S.A.E. correction for NASA GTS. Excellent motor for a GTS2 car or ultralight GTS-3 car. I WILL NOT SHIP. I will put the engine on a pallet and strap it down. Shipping is the buyer's responsibility and pickup must be w/in 10 days of sale. I strongly recommend http://www.uship.com" onclick="window.open(this.href);return false; . I've used them and it works very well and is easy on the wallet. Asking price: $1350 Dyno and video clip of the motor's last run available. Quote
