Technical Bulletin--Side Skirt Modification--8-6-09
  • National Staff
Technical Bulletin (8-6-09):
All vehicles:
Aerodynamics Section Revision:
9) Add or modify side skirts +2 (side skirts must be vertical only, and cannot connect to any other aero component)
Do you consider a fender flare an aero component?
I do, and I don't think I have ever seen a side skirt that wasn't tied in to the fender flares.
  • Members
Theres one:
and another:
and another:
and another:
and another:
and another:
and there are a zillion more that google showed me.
  • National Staff
Shawn, the first two that you showed would not be legal because they are not "vertical only". Flared fenders and rolled fenders are on the no-points mod list (to allow wider tires), but if they are more than just a "flared fender" and have some type of "added" aero component, then they are probably in violation of this anyway:
If a modification is not specifically allowed by the rules, it is prohibited. A permitted item
cannot be modified to perform either a prohibited function, or the function of an item that would
otherwise be assessed points under the modification rules. Vehicle legality is the sole
responsibility of the driver.
  • Members
It was a quick google search that was going more for the "do not attach to a fender flare".
We may need to look into the wording because the stock M3 skirts have some of that aero shape already in them.
