In the process of building my E46 M3 for GTS 3. Would really appreciate some input from those with E46 M3 that have removed the steering wheel lock mechanism. I tried experimenting on a spare column with a DIY that was provided. Didn't quite work out, so before I try it on the car I thought I ask for some help. Thank you in advance for the input.
I did a writeup on this with photos on Bimmerforums, it's in the track section.
That's DIY I tried. Not quite sure what I did wrong on the spare. Just curious if that was the only way to remove it before I try it a second time. This was a really easy thing to do on the E36, but seems to be rather complicated on the E46
Hmmm,
I tried it on a spare and the one on my car, no problems both times. Were you able to get the hardened steel pin out? If you got that out, and removed the "catch" that it holds in place, then you're good to go.
Hmmm,
Ahhh... don't think I got the steel pin out. Thanks for the feedback and help.
