hakeem Posted August 13, 2009 Posted August 13, 2009 Fuel cell - ATL 15 gallon cell, Fuel safe -10 internal surge tank, new foam, modified top-plate for -10 feed and -8 return...you can get down to under a gallon without any starvation on this setup - $500 Custom made aluminum oil catch can with -10 fittings and K&N breather - $50 AFCO dual-pass radiator, bottom port has welded outlet for rotary-friendly 1.5" hose (instead of 1.75") - $100 Setrab 60-row oil cooler, 18x11x2" with -10 fittings, this thing is huge and will cool anything - $400 Tilton triple-master cylinder overhung pedals, have two sets of differing length/pedal ratios - $150/ea 5 different tilton master cylinders - $50/ea, inquire about bore's ECU Haltech E8, flying lead harness terminated for usual rotary setup using GM air and water temp sensors (included), cosmo TPS and bosch-style fuel injectors, replaced CAS and TPS connector with Deutsch connectors (CAS included with setup), 3bar MAP sensor, 4 x LS2 coils and mounting plate, all wrapped in braided sheath, soldered and heatshrink'd properly - $1200 AIM MXL Pista Dash including wiring harness, 2 MSI pressure sensors ($150/ea new), 3 temp sensors, lap timer receiver/beacon, wheel speed sensor, USB cable - $1600 Quote
hakeem Posted August 18, 2009 Author Posted August 18, 2009 Fuel cell, radiator and pedal assemblies are sold. Quote
kjbrew01 Posted August 29, 2009 Posted August 29, 2009 pictures of catch can to [email protected] include details like internal baffleing Quote
hakeem Posted September 3, 2009 Author Posted September 3, 2009 Catch can, fuel cell, radiator, AIM MXL, and pedals are all sold. Quote
