mbuskuhl Posted August 17, 2009 Posted August 17, 2009 Parts located in Garland, TX. Local pickup or shipping is available. PayPal, cash, certified funds accepted. Prices do not include shipping. Reply here or PM if interested. Pictures: http://img178.imageshack.us/gal.php?g=pict0065t.jpg OEM PARTS NA Aluminum Hood: $40: black, some scratches/dings/imperfections S4 NA AFM: $35 5th/6th port sleeves: $5 S4/S5 batter tray: $10: includes tray and all 3 hold down pieces S4/S5 hatch strut: $5 each: 3 available S4NA secondary fuel rail: $10 each: 2 available S4NA ECU: $30: bone stock S4/S5 Leading coil packs: $20 each: 2 available. S4/S5 Tension Bolt Set: $10 : 18 total S4 NA side housings: $75: front, center, rear housings. S5 NA Rotor: $75: 1 available, weight code “S” maybe? AFTERMARKET OR MODIFIED OEM PARTS Carbon fiber NASCAR brake ducts: $50: 3” outlet, these fit nicely in S5 bumper openings. I mounted with 3 small bolts/washers/nuts to the bumper. Bonez/RX7.com intake: $35: filter will be cleaned and oiled for you plus S4 MAF adapter 3.5” x 3.25” HPS silicone coupler: $5: will fit a 3.5” intake to an S4 AFM 3” aluminum mandrel bends: $10 both: intake piping Silicone elbow: $5: 3” x 3” 45 degree NGK S4/S5 plug wires: $10: Like new, maybe 500 miles if that 2GA Battery/Welding Cable: $10: Approx 120” and 57” piece S4NA TB ported/polished and modified: $25: what you see is what you get. No TPS. S4NA ECU: $100: Clipped rev limiter. See it in action here: Flatout Motorsports cooling gauge port: $25 : 1.5” x 1.5” aluminum with (2) ½ NPT Ports Breather Filter: $5 S4 front control arms: $50: newer Energy Suspension bushings installed Idemitsu Rotary 20w50 Synthetic Oil: $4/QT: 4 new available S4/S5 5SPD NA Transmission: $800: Built 10/07 by Jason Saini at Motorsports Enterprises Racing (MER) at a cost of $1400 parts/labor (with receipt) not including donor. New bearings, synchros, shift forks/rod ends, 5/R shift hub, 3/4 hub slider, 1/2 hub slider, all hub slider springs, 3rd gear, 5th gear (upgrade to .756). Custom work on 1/2 shift fork and housing. Used it for 8 weekends and then had it torn down and put back together 9/08 by Buddy Boswell, Mazda Master Mechanic. Never reinstalled, has been sitting ever since. S4/S5 5 lug brake rotors vented: $15/set: All within minimum specs. Front set 1: Brembo, 20.2mm and 20.6mm, freshly turned on brake lathe. Front set 2: Brembo 21.7mm and 21.7mm. Rear set 1: 20.3mm and 20.4mm. Rear set 2: 19.4mm and 19.2mm. Hawk Blue Brake Pads: $40 : Fits 5 lug/4 pot front brakes (complete pair – 4 pads) and rear vented 5 lug discs (3 pads – missing one pad). Good spares. Quote
N1XRR Posted August 25, 2009 Posted August 25, 2009 Still have the plug wires and throttle body? Quote
