macwax Posted August 20, 2009 Share Posted August 20, 2009 I searched but didn't find the answer. John Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted August 20, 2009 Share Posted August 20, 2009 you'd need to run your car through the Performance Touring ruleset its a bit different philosophy - instead of behind handed a modificaiton list you can pick & choose what you want to do with every modification having a points value.. collect enough points and you bump up to the next highest class, and so on fwiw depending on the level of build I've seen most fall between PTE and PTD, but you really need to run through the whole process and tally up your modifications Quote Link to comment Share on other sites More sharing options...
Legends21 Posted August 21, 2009 Share Posted August 21, 2009 What John said is absolutely correct. However, if you are running a Porsche 944 under SCCA ITA, you may also be covered under the 944 Cup rules. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted August 21, 2009 Share Posted August 21, 2009 Dale's post does spark another thought - if its a Honda you'd need to have a set of Toyos but you could run Honda Challenge, if its a German car you could run GTS on any tires and if its a Camaro/Mustang/similar it may fit Camaro-Mustang Challenge or American Iorn (again, Toyos needed) Quote Link to comment Share on other sites More sharing options...
