saleens351 Posted August 21, 2009 Posted August 21, 2009 yellow rims/tires comes with the car black ccw classics will be sold seperate, buyer guys first dibs ($2k for ccw rims&tires 17x10) http://photobucket.com/95clone_2009" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false; Engine: New R302 Block Rebuilt in late 07(Remove & Replace consisting of cylinder block fitted with pistons, rings, connecting rods, crankshaft and all bearings, cylinder heads, camshaft, timing chain, belt and/or sprockets. Included clean and transfer fuel and electrical assembly)(New assembly balanced) -New waterpump & oil pump, steal crank and balanced. -Twisted Wedge aluminum heads came with rebuild Suspension: Barts Works front SLA/rear is maximum motorsports panhard bar and torsen bar (don’t recall the spring rates but it’s a stiff ride) (Koni adjustable shocks) Exhaust: Supercomp long tube headers with x-pipe connected to side a custom side exhaust with no cat, no mufflers Braking: Saleen/alcon 4 piston 13inch slotted front and 12 inch Bear Touring in rear with two-piece custom Coleman rotor and hats. Both front and rear rotors are new, maybe 2 DE events on them. Transmission: TKO 500, 2005 was rebuilt with new syncros and new Tilton 7 Triple Disc clutch system. Interior: cd, stereo, speakers, wiring, backseats, air and heating components all removed. Firewall was installed. Flooring removed and sprayed flat black. Everything else: MSD ignition, Torker II Intake, carbon fiber saleen hood, torsen lock rear end with 3.73 gears, welded 6-point chrome moly cage, balanced aluminum driveshaft, driveshaft loop, carbon fiber air intake (air enters below the windshield), car likes 108-110 octane leaded fuel. Full length subframe connectors. 3qrt manual Accusump put in the trunk, oil cooler recently installed infront of radiator, oil filter relocated to where the battery is, battery moved to trunk as well. Tow hook in front. Bought the car in 05, most of this was already done to it, over the years I’ve been replacing old parts with new parts. Its always been my DE car, probably 3-4 DE’s each summer, now with two kids and new house my tracktime allotted has been to zero. *The car is street legal. *Starter just went out, replacing it with new one as we speak. *car works fine, did a test&tune recently at Heartland Park, ran fine. *Registered as a 1994 mustang GT, title in hand. *I have roughly 10 gallons of 108 fuel left, you can have it. pm me and i'll get back to you. thanks $12,500 Quote
saleens351 Posted August 21, 2009 Author Posted August 21, 2009 oops, forgot to add that I just installed sidepipes, I'll post up pic soon. Quote
Aaron B Posted August 21, 2009 Posted August 21, 2009 What size tires can you run on those black wheels ? Quote
saleens351 Posted August 22, 2009 Author Posted August 22, 2009 What size tires can you run on those black wheels ? previous owner told me 315's Quote
saleens351 Posted August 22, 2009 Author Posted August 22, 2009 Street legal with a carburetor? Location? yes, street legal in Kansas. It has plates, tags, and insurance. Located in southern Kansas City Quote
saleens351 Posted September 1, 2009 Author Posted September 1, 2009 $11,000 Price reduction $1700 for CCW rims and tires Quote
Rook Posted September 15, 2009 Posted September 15, 2009 Damn you, Damien!!!! NEMESIS!!!!!!!!!!!!!!!!!!! (I am so surprised noone beat me to that.) Quote
saleens351 Posted November 14, 2009 Author Posted November 14, 2009 rims have been sold seperately. Quote
