cullen winter Posted August 26, 2009 Posted August 26, 2009 I can deliver this car to Nationals Porsche 944spec race car FOR SALE $7500 1987 Porsche 924S fully race prepared Engine: Professionally built with 4 1/2 race weekends on it cross drilled crank Lindsey Racing oil pan baffle Setrab 19 row oil cooler 951 sending unit new motor mounts all new cooling hoses new radiator (turbo) jumpered primary fan toggle for high power fan new Bosch fuel pump GB matched fuel injectors open diff short 5th Suspension and brakes: Koni adjustable (all four corners) Ground control front coilovers 375# front springs 30mm solid torsion bars 944 turbo front sway bar 26.8mm w/delrin bushings Poly control arm bushings new ball joints and tie rod ends 944 rear sway bar 19mm adjustable adjustable drop links (rear) weltmeister spring plate bushings weltmeister torsion bar bushings good AXXIS Ulitmate pads (all 4 corners) ATE super blue Braided stainless steel brake lines Hawk Blue 9012 front (still in box) Hawk HT-10 rear (new) KFP Gold rears Safety and interior: Hanksville custom welded cage w/nascar style bars SFI roll cage padding Sparco Pro2000 seat (FIA made in 2005) new cover Schroth 6 point cam lock harness Sparco window net Safety Solutions right side net Longacre 4 post kill switch SPA 4 litre fire system (mechanical, nozzles on fuel rail, exhaust and driver) Momo hub adaptor Nivola steering wheel Camera mount Sparco passenger seat Sabelt 5 point harness Factory half dash with OEM pod (tach rotated) 6 panel wink mirror New windshield steering column lock removed ignition toggle push button start Equus oil temp, oil pressure and amp gauges (mechanical) Other: 8 15x7 Phone dials (6 w/Toyo R888 scrubs, 2 w/street radials) 2 15x6 Phone dials (street radials) Includes flat tow hardware and lights Car weighs 2625 with 170 # driver and 2 gallons fuel (2600 empty without passenger seat) Still has wipers and headlights (headlight mechanism removed, wingnut system) Lexan door windows Street legal, registered in N.M. Spares: intake w/throttle body and TPS cam housing fuel pump rear brake calipers steel control arm misc relays and fuses new starter You will be fully ready to run up front with this car. Very reliable. My daughter's hockey career takes priority over my addiction for the next few years, so it's time to adjust my debt ratio !! Will consider delivery within reason. More pics available on request. Feel free to e-mail or call with questions 575-741-5207 Thanks Quote
