new LAKEWOOD #15230 1996-03 MUSTANG SAFETY BELLHOUSING 300
e-mail [email protected] if your interested
loveland OH 45140
$300
LAKEWOOD #15230 SAFETY BELLHOUSING
Fits Ford 1996-03 Mustang with 4.6L/5.4L V-8.
Notes: Will not fit T-45, T-56 or TR3650. Can be used with Jerico DR-4 transmission having the proper input shaft. Transmission Tremec TR3550 & TKO w/7.200" Input shaft. Bore Diameter 4.850. Depth w/Block Plate 6.924. Fork Opening 2.81 x 3.75.
The stock cast aluminum bellhousing is adequate for OEM applications, but mounted behind a high horsepower - high RPM engine, the cast aluminum bellhousing could become deadly shrapnel in the event of a clutch/flywheel explosion. Hydroformed from premium quality steel plate to ensure uniform thickness throughout for superior strength. Stress relieved after forming results in a stronger, safer bellhousing. Mig-welded threaded inserts for transmission mounting bolts, clutch pivot ball and clutch linkage brackets where required. Precision machined to assure proper bolt hole and center bore alignment. Blanchard ground mounting surfaces for precise parallel alignment of engine and transmission. Dedicated applications assure a direct fit for all popular passenger cars. Approved by all major racing sanctioning bodies and meet SFI 6.1 specifications. Complete with safety block plate and grade 8 hardware. Fits Ford 1996-03 Mustang with 4.6L/5.4L V-8. Notes: Will not fit T-45, T-56 or TR3650. Can be used with Jerico DR-4 transmission having the proper input shaft. Transmission Tremec TR3550 & TKO w/7.200" Input shaft. Bore Diameter 4.850. Depth w/Block Plate 6.924. Fork Opening 2.81 x 3.75.
__________________
