RockLobster Posted November 25, 2009 Share Posted November 25, 2009 Any pre-release info on the track width rules? Quote Link to comment Share on other sites More sharing options...
Grant Posted November 26, 2009 Share Posted November 26, 2009 R6's stay at +10 points.A6's and C91 and C90 Z214 Hankooks move to +13 points. Good to hear for those of us who don't like buying tires. RA-1s move to +7 points (no more +5 category).Hmm, sounds like *Specs and XSs are going to be more popular (which is fine with me, see above). Quote Link to comment Share on other sites More sharing options...
ff2skip Posted November 26, 2009 Share Posted November 26, 2009 The only reason why I'm sad to see the +5 tires go away is that those of us blessed with two *'s and want to stay in our base class can only run the sticky stuff if we downsize by at least 20mm. I haven't looked at the weights and all but I think the CR should probly be a * rather than a ** still with a 225 Hoosier and a free remap from that new hondata thing you should be hauling ass. You and undersized tires! Quote Link to comment Share on other sites More sharing options...
IGZOSTD Posted November 26, 2009 Share Posted November 26, 2009 So with a Hankook you still get to chose a c51 or c71 for door # 10 Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted November 26, 2009 National Staff Share Posted November 26, 2009 Yes. Only the C90 and C91 are moving to +13. You can still use the C71 or C51 for +10. Quote Link to comment Share on other sites More sharing options...
Joshua Posted November 26, 2009 Share Posted November 26, 2009 Thanks for posting this information Greg. Happy Thanksgiving! Quote Link to comment Share on other sites More sharing options...
hancheyb Posted December 2, 2009 Share Posted December 2, 2009 Pre-Thanksgiving Giveaway (NOT OFFICIALLY APPROVED YET--but 99.9% chance):1) Non-OEM shocks/struts/dampers with an external reservoir or more than two ranges of adjustment—must still take points for springs below +10 (example: compression (bump) and both high & low rebound adjustments). 2) Non-OEM shocks/struts/dampers with a “Piggyback” external reservoir or with shaft diameter 40mm or greater —must still take additional points for the springs below +7 3) Non-OEM or modified/re-valved shocks/struts/dampers +3 (all others)(springs not included) Get your list to Santa now! I like the price limit removed. Is a Bilstein Sport Strut 40mm or slightly smaller? I think they measure 39.9 which explains the 40mm limit? I'll measure one tomorrow for grins. EDIT: I measured an Evo X MR Bilstein and BMW E36 M3 Bilstein. Both were 39.90mm FWIW. Quote Link to comment Share on other sites More sharing options...
ff2skip Posted December 9, 2009 Share Posted December 9, 2009 Just wanted to say "Thanks" for getting the rules posted. Quote Link to comment Share on other sites More sharing options...
Varkwso Posted December 10, 2009 Share Posted December 10, 2009 Just wanted to say "Thanks" for getting the rules posted. I agree. Great job guys! Quote Link to comment Share on other sites More sharing options...
BlkGt3 Posted December 11, 2009 Share Posted December 11, 2009 Pre-Thanksgiving Giveaway (NOT OFFICIALLY APPROVED YET--but 99.9% chance):1) Non-OEM shocks/struts/dampers with an external reservoir or more than two ranges of adjustment—must still take points for springs below +10 (example: compression (bump) and both high & low rebound adjustments). 2) Non-OEM shocks/struts/dampers with a “Piggyback” external reservoir or with shaft diameter 40mm or greater —must still take additional points for the springs below +7 3) Non-OEM or modified/re-valved shocks/struts/dampers +3 (all others)(springs not included) Get your list to Santa now! I like the price limit removed. Is a Bilstein Sport Strut 40mm or slightly smaller? I think they measure 39.9 which explains the 40mm limit? I'll measure one tomorrow for grins. EDIT: I measured an Evo X MR Bilstein and BMW E36 M3 Bilstein. Both were 39.90mm FWIW. Shaft diameter not the shock body. This rule looks like it was aimed @ the AST shocks with their large shaft. Peter Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted December 12, 2009 National Staff Share Posted December 12, 2009 No, we actually had the 40mm shaft language in a few of the drafts of the rules back in '06 and '07, but we elected to go with the dollar cap instead because there were a few "junk" shocks from overseas that had the larger shafts and cost way under the $3000 and $4200 caps. The dollar caps picked off all of the good shocks with the large shafts. Also, I think that the AST shocks in question earlier this year are smaller than 40mm anyway. I think it is their more expensive shocks that have the 40mm+ shafts. Quote Link to comment Share on other sites More sharing options...
Mrsideways Posted December 16, 2009 Share Posted December 16, 2009 Well, Between the AST's and the Alcohol removal the mini's not gonna be competitive unless I can figure out a way of using liquid nitrogen to cool the intake charge. That Tiny supercharger just creates to much heat. Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted December 16, 2009 National Staff Share Posted December 16, 2009 What do the AST's have to do with it? If you had the 40mm+ shafts, then you should have been taking the +7 points already for going over the $3000 price cap. You can still run straight water injection if you want as well. Quote Link to comment Share on other sites More sharing options...
Mrsideways Posted December 16, 2009 Share Posted December 16, 2009 Nope, they were under $3000. http://www.vorshlag.com/product_info.php?cPath=45_131_189&products_id=309 The Water alone won't do the job. I'll figure something out, just don't feel like spending the money on the engineering needed to do it. Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted December 16, 2009 National Staff Share Posted December 16, 2009 Hmmm, it looks like it depends on what car model you have whether or not the 5100's have the big shafts or not. Also, it looks like your model requires you to take the extra +1 for inverted shocks, while others do not. Quote Link to comment Share on other sites More sharing options...
Mrsideways Posted December 16, 2009 Share Posted December 16, 2009 Correct, I took the 1 point. Quote Link to comment Share on other sites More sharing options...
