FS: 1997 BMW 328is e36 race car
8legs Racing #11 - 1997 BMW 328is
Originally built off the showroom floor by Franz Blam Racing for Motorola Cup/Speedvision Cup racing.
Car is BMW CR DM legal and competitive (won DM class at Sebring Winterfest 2009, and finished 5th in the 6hr Enduro ... 42 sec off 3rd place 'casue we almost ran out of gas!).
This car is very well sorted and runs a 1:33.x at Mosport and 2:19.x at CMP on 235 Toyo R888s. Many spares will be included. Turn key race car ... needs absolutely no work except a good cleaning and wax to go racing (waxing makes the car faster ya know!)
Here are some specs on the car ... more details can be provided on demand:
- 1997 BMW 328is, no sunroof chassis, built off showroom floor
- Motorola cup cage (6 point)
- Engine is OBDI M52 11.5:1 CP forged pistons, 84.5mm bore. Crank and flywheel are balanced
- Engine rebuilt in 2009 with new bearings, seals, etc.
- Sunbelt M3 sport cams, 24# injectors, 3.5" HFM, other bolt-ons
- PWR 57mm aluminum rad and zionsville comeption cooling kit (shroud, tank, 16" spal fan)
- Sachs 4 puck race clutch (strapless), lightweight flywheel
- JRZ double adjustable, external res shocks, rebuilt by Joe at SRP in 2009
- Spherical or solid bushings and bearings at all points
- 3:73 30/90 race diff by diffsonline, RE finned diff cover
- Bimmerworld carbon wing
- stock dash (gutted), OE cluster, defog 4" fan routed to ducts
- G2X GPS Datalogger
- lexan rear and quarter windows, OE front windshield
- OE fuel tank, dual pump setup. Will do 95+ minutes at Mosport and Sebring on 1 tank
- Grand Am style dry break fuel fillers
- wiring harness completely stripped to bare minimum to run the car (stock 413/506 OBD1 DME harness). Custom software by BimmerWorld
- Autometer gauges (Oil temp, Oil press, water temp), remote mount oil pressure/temp senders
- Headlights (high and low beam), taillights fully functional
- Seat is Sparco Pro2000 belts are Schroth Hybrid II new in 2008
- OE M3 brakes, HT14 front pads, HT10 rear pads, OE OBDI ABS (on/off switchable)
- Current setup is 800# front, 900# rear springs 2.25"
- front swaybar is tubular, blade style adjustable, rear is Eibach 3-way adj.
- Front and rear subframe reinforced, solid Al bushings and engine mounts.
- Turner rear control arms, GC weight jacks, GC camber plates.
- custom stainless exhaust 3" mandrel bent with muffler
- Remus/IE shorty headers
- Race weight (without driver) is ~2550#
Asking price: $19,999 USD all in, however price can be adjusted based what will be included
email: sales atsign 8legsRacing.com for details
