FS: Audi A Q
2001 Audi A4 Q. Silver color. Built for road racing in NASA or SCCA.
8 pt DOM steel roll-cage. All required bars to spec, 1.75" x .120"
Additional bracing is done in 1.5" x .095 for weight savings
Front support bars welded to strut housings and triangulated to downbars at base of A-Pillar
Rear shock housings "X" braced with main hoop.
NASCAR style driver's side bars. "X" bars on right side.
2.8L V6 12V engine built by Robello Racing Engines for Stasis Engineering to race in Speed World Challenge Touring Car. *Dyno rated at 300 Hp
Alcon calipers, front
Alcon calipers, rear
Alcon rotor set, front
Stasis / Ohlins Motorsport Damper set, tuned to Stasis Touring Car specifications
Complete dry sump system
Spare dry sump pump
Spare sub-frame
Complete spare uprights and control arms (front and rear)
Complete chassis wiring harness
World Challenge spec rear wing
Tilton floor-mounted pedal assembly
Spare steering rack
5 spd Ur S4 gearbox w/ Stasis LSD fitted
4.11 rear diff
Stasis rear LSD
SPA Fire system, 4L
Spare carbon fiber hood
Fuel Safe 15 Gal fuel cell w/ dual-internal pumps
Tilton flywheel for dual-disc clutch
Spare V6 engine gasket set
Stainless steel header set
EFI Technology 2.1 ECU (up to 8 Cyl)
Mil-spec wire harness for 6 cyl engine
8 Ch CDI Ignition Box
OMP race seat w/ head restraints
Aluminum seat side mount brackets
Car is ideal for competing in NASA GTS or SCCA Super Touring (under 3L).
Also have 2 other engines that would be good for spares.
Car is currently incomplete. Would need all of the above mentioned parts installed. Could complete the car as part of the sale, or not. Would also sell roller alone.
Make an offer. email [email protected] or call 562-694-2226
Will post pics as soon.
Where is the car and do you have an idea as to what kind of offer you are looking for?
Car is here at our shop:
DRS
700 E. Lambert Rd Units I & J
La Habra CA 90631
Ph 562-694-2226
Delivery within 500 mls is a possibility depending on the terms of the sale.
The Ohlins dameprs, Alcons, rotors, and rear LSD are all NEW *AS IN NEVER EVEN BEEN INSTALLED
The tranny was rebuilt by Stasis with the rear-bias diff installed. This also has not been used.
The value of the chassis, dampers, brakes, tranny, and diffs adds up to $17K
The ECU was a GrandAM level ECU in 2005 and was $5,995 new back then.
All the other parts are usd, but in VERY good condition.
This car was essentially going to be comperable to what Stasis ran in Speed Touring a few years ago.
Too busy with other things to finish the project and I could use the space here at the shop. If no one wants it I will just finish it and drive it eventually. I don't need to give it away... but would like for it to go to a good owner who will enjoy it.
If you're interested throw a reasonable number at me.
