91rs13 Posted November 12, 2009 Posted November 12, 2009 1983 BMW 320i Race Car Well Sorted Turn Key car Ready for Autocross, Race or Track duty. Car was prepped for SCCA F Street Prepared ( autocross ) and used regularly by a BMWCCA instructor for Drivers schools / HPDE’s. This is a well sorted car and needs nothing ( well fresh rubber would be good) and is turn key- ready to go with a comprehensive spares package. It could be road-raced with BMWCCA, SCCA or NASA etc, but may need modification for rules ( again car was prepped with SCCA Solo in mind). The Car is solid with a nice Roll Cage, aluminum seats, coil-overs and a reliable motor. The car has a title and could be street registered ( it has not been for some time) --- Overall the car is in fantastic shape, but in full disclosure there is some very light rust on the LF fender ( comes with a spare) and on the rear valance –Nothing structural or needing heavy repairs! 1983 E21 BMW 320i with a 4 cylinder M10 1.8L motor, 219,300 mi on chassis, Engine- Mileage : 95,000mi. Header/ Top End Performance muffler system Twin -Webber 40 DCOE Side Draft Carburetors Baffled Oil Pan Steel Left Side motor Mount/ new rubber mounts Accel Coil Suspension- Ground Control Coil Over 600lb F 500lb R Koni Shocks Custom Valved Single external adjustable -front Double external adjustable-rear Ground Control Racing Camber Plates 21mm Front Sway Bar 3 Position Rear Sway Bar / urethane links Urethane Bushings in rear trailing arms Stainless Steel Flex Brake Lines New Front to Rear Fuel and Brake Lines New Master Cylinder Body- Good Solid Full 8 Point Roll Cage- 1 ½” DOM Tubing .120 wall tube Battery Relocated to RR of trunk Quick Release Steering Wheel Kirkey Seat 6 Point Harnesses Wheels- --4 Sets Set of 4 aluminum 15”x 7” Set of 4 steel 13”x 8” diamond racing Set of 4 aluminum 13”x 5 ½” Set of 4 basket weave 13”x5 ½” aluminum SPARES 1 Complete engine – rebuildable , 2 additional 1.8L heads LF Fender Spare throttle cables 4 Front Strut Assemblies -2 / springs(stock) 2 transmissions 1 good, 1 need input shaft Spare Flywheels Spare Alternator 2 Spare 200lb. coil over springs 2 Spare 350lb. coil over springs Spare Sway Bars front and Rear Xtra stock shocks front and rear stock Spare clutches Extra sway bars and links Extra brake pads and calipers Extra front hubs Good Rear Trailing arms LS and RS Fuel Pressure Regulator and Guage Awards 2009- 1st place SCCA North East Region Divisional Champion 2nd place SCCA National Tour SCCA Mo-Hud Region Street Prepared Champion ( pending) 2008- 2nd place SCCA National Tour NE 3rd Place SCCA Pro Tour- 2nd Place North East Division Championships Contact Bruce Kosakoski – 518-674-8816 or [email protected] $4495 OBO. Photos Here http://picasaweb.google.com/91rs13/BrucesBMW?feat=directlink Quote
