Acura Integra Type R
Posted (edited)
Acura Integra Type R 2002 Grand-Am Cup Championship winning car biult by Mugen/King Motorsports
Currently running in PTB configuration wins in everything from Grand-Am, NASA, SCCA including various track records.
Laptimes-
PIR 1:08:6
FIR East 1:03
FIR main 1:08
Willow Springs 1:34 prob a couple of seconds left easily...
RyanF jumped in the car first time ran a low 1:34 in one lap and came in so?
239/162 at 2285lbs with 200lbs driver empty
Engine
NEW ENGINE
92mm Crower stroke
Crower lite "long rods" big bolts
84.5 Endyne pistons
Cleavite race bearings
Entire new fresh trick head with oversized stainless valve
GSR block with Darton sleeves
motor was $10k all the right parts!
Fresh trans-sychro's, 3rd gear, inter-lock, ect..
new competition race clutch with "new 8lb flywheel"
I think there is about 3 hours on the trans and complete engine-
please see ad above for details and spares package-
Makes 239WHP
now the car wieght 2285 w/200lb driver.
Endyne component
Endyne's full ported head
oem laser cut golden eagle head gasket
.5 over stainless swirl polished valves
Eibach valve springs, tit retainers
84.5mm Endyne high dome pistons with wrist pin moved up
Crower long rod set up with big bolts
Darton Sleeved GSR
polished/mag'd crank
M1 and filter changed after every race weekend
Mugen 4/1 header also have Hytech 4/2/1 replica rewelded with skid plates and for better clarenance
3 muffler set-ups
dyno tuned intake-- (2 types) both with air horn velocity stacks
ported Skunk2 intake manifold also have ported ITR manifold
70mm Skunk2 Throttle body
run stock balancer-spare CTR/N1
Chassis
Carbon fiber hood
Lexan front windshield
Lexan rear hatch
new front upper control arms with PT legal camber adjustment (offset delrin bushings and slotted)
(spare) Skunk2's UCA
new stock shimmed rear control arms-spare skunk2 rears
Mugen sway bars
Buddy Club race spec shocks currently 16k/18k extra springs avail
new ball joints
new sway bar bushings
3 sets of ssr wheels 7.5inch various Hoosier R's and A's
Hasport mounts
Hasport axles with 3 spares
stock rear ITR wing on car/carbon fiber rear spare
home made 3 inch splitter
Electronics
Stack Instrument cluster lap times, parameters, ect..
new locash wiring harness with cleaned grounds
Hondata s300 also 1 mugen ECU, 2, Neptune chipped ECU's
New Walboro Fuel Pump, filter
NEW Fuel Safe Fuel cell- with new dual wiring harness
new ignition switch
New fuel / ignition relay
new TPS
New Map
RC 550cc balanced injectors
New AEM fuel pressure regulator
new distributor-Spare new in box along with various spare ignitors, ect...
new plug wires
new spark plugs
Trans
ITR 6 months freshed with new synchro's 3/4th and new 3rd gear
fluid changed every 2 race weekends)
New comp clutch
spare master/slave's/calipers
Hawk blue/blacks spares
spare rotors
Safety
Recaro seat
New 6 point FIA harness
side net
electronic Fire system plumbed to engine and driver
hand held unit too
Cage is stitch welded to the unibody
Fuel pump circuit breaker and toggle switch
ABS on/off toggle switch
TONS of spares!
http://www.hondachallenge.com/albums/comp/aaz.jpg" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
The car now has Lexan frt/rear and a carbon fiber hood....cold air through the pass. headlight W/black bumper cover still have a spare white.
The bad the body shows dings, some tire donuts, ect...
It has been a race car for it's entire life although it looks great from 10 well maybe 15ft away!!!
Located in Phoenix Arizona-$14,500 would consider trades for?
Paul Bloomberg
[email protected]
  • 5 months later...
Posted (edited)
NEW ENGINE
92mm Crower stroke
84.5 Endyne pistons
Will trade for ???
Looking for a gas mileage efficient driver
and race or TT car---->miata, BMW E36 M3, older Porsche (944T or affordable 911)
Makes 239WHP
How about an e30 with an m50 swap built for TTE? Still street legal with a cat, etc.
  • 3 months later...
So NOW there is a new motor(see above)- refreshed trans w/JDM FD!
Tons of spares and tires!
Make a reasonable offer and it's yours!
(removed more weight)
The car with me at 200lbs is a adjusted 10.251 pwr/lbs at classing weight (242/2275)although it can't hit that min weight by about 10lbs even when dry.
Oh yes it has also has fresh re-valved shocks for the 1000k springs....
I respond to email only-
PaulB
[email protected]
  • 9 months later...
new price $12,500 firm with all the spares---->everything
