FS: 2003 Apex Silver Evo VIII
Engine : Most parts from Buschur Racing (BR) and the dyno tuning work on the car has been done by IveyTune, one of the best 4G63 tuning shops in the country. Last time on the dyno with a mild tune it produced a safe 371AWHP on 93oct pump.
Note it passed NJ inspection last May.
Buschur air filter kit
Buschur 3" down pipe
Buschur 3" test pipe
Buschur mass airflow pipe kit
Buschur Small Battery
Buschur Upper I/C pipe
Buschur Lower I/C pipe
Buschur Ported o2 Housing
Buschur Race FMIC
Buschur Manual Boost Controller
HKS 272 Intake and Exhaust Cam
HKS SSQV BOV-recirculating
HKS 3" carbon fiber catback exhaust
ARP Head Studs
Brian Crower Valve Spring/Retainers
SuperTech valves
SuperTech valve guides
ForcedPerformance Green 73Hta Turbo-(18psi wastegate spring+ported hotside,80mm port)
ForcedPerformance Upgraded Turbo Oil Feed Line
Ported Exhaust manifold
750cc Precision injectors
Walbro 255lph fuel pump
Exedy Twin-Disc Clutch
Perrin Oil Catch Can/Overflow Tank (black)
Samco Sport Radiator Hose Kit
Kevlar timing belt
*Turbo,rotors,pads,clutch, head all have less then 2000 miles on them
*As the car sits right now, it weighs just about 3050lbs(with stock interior) still room for more weight reduction if needed
Suspension/Brakes : RobiSpec suspension installed and set up by Rob Fuller (Robi) himself. This is one of the best handling Evo VIII’s you will find and is well suited for Autocross, Track or Time Attack performance
RobiSpec Clubsport Coilovers
RobiSpec Adjustable Front & Rear Sway bars
Frontline Bushings all around
RacingBrake 2piece slotted/drilled front rotors
RacingBrake 1 piece slotted rear rotors
Frontline Roll Center Kit
Corner weighted and balanced
GtSpec Rear Strut Bar
Motul RBF 600 Brake Fluid
Ferodo DS-2500 Brake Pads
Goodridge Stainless Steel Brake Lines
Enkei RPF1 17x8.5 lightweight Wheels with 235/45R17 Summer tires
Electronics :
Autometer 30-0-30 boost gauge
Calibre K40 onboard radar detector
Alpine CDA 9815 Head Unit
MB Quartz Interior Speakers
Custom Component/Coaxial Mount
Buschur Camera mount
Other :
I’ll included a set of track wheels (stock Enkeis in black) and used Kuhmo V710 R compound tires. There’s several auto crosses or a track day or two left on the tires. I have some of the original parts, including all the suspension as well.
35,000 miles asking $23,995
*Price Reduction $21,995
