BsmoothR Posted November 23, 2009 Posted November 23, 2009 For Sale 2004 Mitsubishi Lancer Evolution GSR Grassroots Motorsports Ultimate Track Car Challenge UTCC Suspension Cusco Zero2R 02R full body inverted race coilovers Robi spec adjustable rear bar New OEM rear control arm bushings Whiteline rear bump steer kit Perrin PSS. Front/rear control arm bushings(Bumps positive caster up)AMAZINGMOD! Whiteline front control arm bushings Whiteline roll center kit tie rods & ball joints FastAction alignment on laser type John Beam machine New OEM front wheel bearings custom cross member reinforcement Brakes Stop tech Full Big brake kit Front &rear Ferroda 2500 pads freshly seated 2 piece cross drilled rotors stainless lines fresh AP fluid Drivetrain Exedy twin carbon clutch kit Bushwacker 5 spd trans(previous owner) New oem fluids (Tcase&trans) New oem throw bearing w/multi wave springs Engine MR 10.5 turbo((9k miles) 272 XS engineering cams (great idle,performance & sound) FastAction 2.5 piping Hallman BC FastAction Light weight gel battery & tray Buschur mani heatshield Full 3'' Injen exhaust & down pipe Ported Megan o2 housing Magnacore wires /NGK plugs Az airfilter I can part with the wheels,coilovers & brakes.to bring it to $14,000 Don't want to sell but need to finish some other projects. Quote
