2010 Enduro Ruleset - looks like big classing changes
kbrew8991
 Share
  • 2 weeks later...
Sorting by class:
ES
AIX NASA
AM BMW CCA
ASC NASA
BM BMW CCA
EF BMW CCA
EM BMW CCA
GS1 Grand Am 2003 or earlier
GT1 SCCA
GT2 SCCA
GTA SCCA
GTS4 NASA
GTS5 NASA
PRC (all) NASA
SGS Grand Am
SM BMW CCA
SP SCCA
ST1 NASA Super Touring
SU NASA
T1 SCCA
Trans Am SCCA
VVC1 NASA
VVC2 NASA
VVCX NASA
WCGT SCCA World Challenge GT
E0:
AI NASA
AS SCCA American Sedan
CM BMW CCA Formerly ES
DM BMW CCA Formerly ES
EP SCCA Formerly ES On DOT tires; otherwise ES
FP SCCA On DOT tires; otherwise ES
GS Grand Am 2004 rules and later
GS2 Grand Am 2003 or earlier
GT3 SCCA Formerly ES
GTS3 NASA
HC1 NASA
HP BMW CCA Formerly ES
IP BMW CCA
PRC-GTS NASA new classing for 2010
PTA NASA Formerly ES Tires used determine PT tire points assessment
PTB NASA Tires used determine PT tire points assessment
SRX NASA Nissan SE-R Cup - Extreme
ST Grand Am
ST2 NASA Formerly ES
T2 SCCA
WCT SCCA World Challenge Formerly ES
E1:
CMC2 NASA Formerly E0
FFR NASA Formerly E0
GP SCCA On DOT tires; otherwise ES
GT4 SCCA Formerly E0 On DOT tires; otherwise ES
GT5 SCCA On DOT tires; otherwise ES
GTS2 NASA
HC2 NASA
HS BMW CCA Formerly E0
IS BMW CCA Formerly E0
ITR SCCA Formerly E0
JP BMW CCA Formerly E0
KP BMW CCA
MX5 Cup SCCA
PS0 NASA
PTC NASA Tires used determine PT tire points assessment
RS SCCA Cal Club Formerly E0
Spc Boxter PCA
Spc Boxter POC
Spec E36 NASA Formerly E0
Spec E36 BMC CCA Formerly E0
SR POC Boxster Formerly E0
T3 SCCA
USTCC NASA Formerly E0
E2:
CMC NASA Formerly E1
CS NASA MINI Challenge-CS
GTS1 NASA
HC3 NASA Formerly E1
ITS SCCA Formerly E1
JS BMW CCA Formerly E1
KS BMW CCA
Legends INEX Formerly E3 Must use spec tires & 5 gal tank
LP BMW CCA Formerly E1
MP BMW CCA
PS1 NASA
PTD NASA Formerly E1 Tires used determine PT tire points assessment
TR INEX Formerly E3 Thunder Roadster (w/ OEM fuel tank)
E3
944-Spec NASA Formerly E2
C NASA MINI Challenge-C
GTI Cup NASA
HC4 NASA Formerly E2
HC5 NASA
HP SCCA Formerly E2 On DOT tires; otherwise ES
ITA SCCA Formerly E2
ITB SCCA
ITC SCCA
LS BMW CCA
MS BMW CCA
NC SCCA Neon Cup Formerly E2
PCTCC NASA Formerly E2
Pro7 NASA
PS2 NASA
PS3 NASA
PS7 NASA
PTE NASA Formerly E2 Tires used determine PT tire points assessment
PTF NASA Formerly E2 Tires used determine PT tire points assessment
SER NASA Formerly E2 Nissan SE-R Cup
SF NASA Formerly E2 Spec Focus
SM NASA/SCCA Formerly E2 Spec Miata
SN NASA Formerly E2 Spec Neon
Spec E30 NASA Formerly E2
Spec7 SCCA Formerly E2
SSB SCCA Formerly E2
SSC SCCA
why did USTCC get moved back to E1???
The power to weight ratio for the cars are much much much much more along the lines of H1, GA ST, etc...
Looks like they are trying to make E3 a class again...
I've said it before but IMO, all of the "pro series" cars, USTCC, Grand Am, World Challenge, should all be in ES.
The rules and "target speed" are always changing.
Look at WC, and the crazy weird new classing they have.
WC TC are now ~5 seconds slower then previous. They are along the lines of T3 cars.
Some of it seems kind of arbitrary. For example, ITA got moved to E3, but none of the GTS classes changed.
A pro built 1.8 ITA Miata will put about 130 to the ground, at 2380 lbs. That works out to about 18 lbs per HP, which if it was a BMW E30 instead of a Miata fits in GTS2.
GTS2 is mapped two classes higher in E1.
Why are all the numerous "retired" NASA classes still in there?
imho ITA is an overdog for the new E3, but that appeal fell on deaf ears Its about 2-4 seconds a lap clear of the rest of the field.
GTS in general is a VERY open ruleset, I'm not sure I'd try and compare IT, PT, etc classings to it. There is more to laptimes than simply horsepower to weight ratios.
OK, then why did STS2 move down to E0? It is just as open, but can have an “Adjusted” wt/hp ratio up to 8.70:1 8.7 to 1 is roughly equivalent to GTS4, which is ES.
Maybe I am wrong, looking at lap times from the last 2 NASA nationals. Keep in mind that the Honda Challenge times would be a little faster as they are not limited to Toyos in an enduro.
Times at Mid-Ohio form the 2008 nationals, plus the SCCA regional track records.
E3
Spec Miata Mazda Miata 1994 01:43.0
PTE Nissan Sentra SE-R 1992 01:43.7
ITA 1:42.939 regional track record
E2
GTS1 Porsche 924S 1988 01:43.6
CMC chevrolet camaro 1995 01:43.6
PTD nissan 240z 1972 01:42.9
ITS 1:42.588 regional track record
E1
GTS2 Porsche 944 1985 01:40.2
Honda Chal 2 acura type R 1995 01:42.3
Factory Five Challenge 01:40.2
PTC Dodge Neon SRT4 2004 01:40.9
E0
GTS3 BMW M3 1997 01:35.6
Honda Chal 1 Acura TL 2007 01:38.2
PTA BMW M3 1995 01:36.5
Super Touring 2 Chevrolet Corvette 2003 01:33.8
American Iron Ford Mustang 2005 01:37.3
EP 1:37.054 E-Prod, regional track record, assumed on slicks which would put it in ES
Times at Miller from the 2009 Nationals
E3
Spec Miata 2:18.9
PTE 2:18.736
E2
GTS1 2:18.923
CMC 2:18.911
PTD 2:17.857
E1
GTS2 2:15.470
Honda Chal 2 2:15.493
Factory Five Challenge 2:12.361
PTC 2:12.226
E0
GTS3 2:08.637
Honda Chal 1 2:10.957
PTA 2:07.019
Super Touring 2 2:06.025
American Iron 2:08.728
Keep in mind enduro classing is done based on car/ruleset potential, not last yaers laptimes.
The 924S that won GTS-1 this year was a Spec car on DOT's, and no where near what a GTS-1 cars potential is. It won becuase no one built/brought a more fully developed GTS-1 car, and it was driven well.
I don't believe ST allows a partial tube frame chassis with completely custom suspension pick up points, unlimited aero mods, etc. Nothing is as wide open as GTS rules.
There is more than meets the eye in enduro classing.
you don't know ST classing very well - its just as wide open as what you described.
I'm seeing alot more inconsistencies the more I look at these changes...
 Share
