944-Spec#94 Posted January 11, 2005 Share Posted January 11, 2005 Ok Gang.... The latest 2005 Rules are here. Actually they were hear last week and I was late in publishing. Unfortunalty I am having some issues publishing from work (firewall probably) so I published to my rennlist account. Here is a link http://members.rennlist.com/m758/944-spec_rules_2005_V2.23.pdf I will publish to the 944-spec site ASAP! Quote Link to comment Share on other sites More sharing options...
Packfill Posted January 12, 2005 Share Posted January 12, 2005 Just read the 2005 rules....I need clarification..... Throttle Cams are now in. Roll Cage welded to the A-B Pillar is now out. Correct? Quote Link to comment Share on other sites More sharing options...
PeanutinCA Posted January 12, 2005 Share Posted January 12, 2005 Throttle Cams are now in. I guess so. 12.7 Throttle Cam The throttle cam may be modified or replaced. Roll Cage welded to the A-B Pillar is now out. No, it's now in. 6.2 Roll Cages Roll Cages must mount to the chassis with no more than six primary points and cannot mount past the firewall. The front floor mounts must be either on the floor or the doorsill of the car. Cages may be welded to the A and B pillars for safety. Cages may bebolted or welded in place. P.Dilly. Off to the Cage shop. Quote Link to comment Share on other sites More sharing options...
Packfill Posted January 12, 2005 Share Posted January 12, 2005 JM-Off to the Cam Store.... Quote Link to comment Share on other sites More sharing options...
PeanutinCA Posted January 12, 2005 Share Posted January 12, 2005 Just cut it with a saw, no need to buy anything. Just cut the extra arm of, done! Quote Link to comment Share on other sites More sharing options...
Packfill Posted January 12, 2005 Share Posted January 12, 2005 Yeah, but its only $25, and it's RED!!! Quote Link to comment Share on other sites More sharing options...
PeanutinCA Posted January 12, 2005 Share Posted January 12, 2005 ... and it's RED!!! That will definitely make you go faster then!! P.Dilly. Quote Link to comment Share on other sites More sharing options...
944-Spec#94 Posted January 12, 2005 Author Share Posted January 12, 2005 ... and it's RED!!! That will definitely make you go faster then!! P.Dilly. That is why my entire car is red... Wonder why Tim got that red 944? Cause everyone knows Red is faster! Quote Link to comment Share on other sites More sharing options...
