mweeks Posted January 19, 2005 Posted January 19, 2005 Does the oil pump in an N/A car have enough pressure for a turbo oil cooler? Quote
944-Spec#94 Posted January 19, 2005 Posted January 19, 2005 ...If so the 951 has exactly the same oil pump as a N/A car, and the pressure drop is the same or slightly better than the very restrictive factory oil/water cooling system.... Greg F. Greg Posted this in another thread. (my PIR report thread) Quote
mweeks Posted January 20, 2005 Author Posted January 20, 2005 Does the external oil cooler need to be from a 951 or can I use any type? ie. after market. And what about an Accusump? are they legal and would'nt it be a help with oil pressure drops? Quote
944-Spec#94 Posted January 20, 2005 Posted January 20, 2005 The cooler can be any type and you may add an accusump. Quote
