1slowspec3 Posted April 7, 2010 Share Posted April 7, 2010 here is my specs.. what do you guys think of my alignment ? L R caster 5.5 5.4 camber -2.8 -2.8 Toe 0 0 Rear Camber -2.5 -2.5 Toe 1/16'' 1/16'' I just put new tie rods and need a new alignment. anything i should change? Should i change anything with my front toe? Quote Link to comment Share on other sites More sharing options...
matt325 Posted April 7, 2010 Share Posted April 7, 2010 L R caster about 6 camber -2.4 -2.6 Total Toe: 1/16" toe out Rear Camber -1.8 -1.8 Total Toe: 1/8" toe in These are just starting, but based on pretty conventional BMW M3 track settings (which are usually for 17 in. whees) I am going to adjust based on tire temp readings once on the track. BTW, here is a screaming deal on toe plates on Ebay http://cgi.ebay.com/ebaymotors/Toe-In-Plates_W0QQitemZ170466342080QQcmdZViewItemQQptZRace_Car_Parts?hash=item27b095f4c0#ht_500wt_917 These, as far as I can tell, are exactly like the Longacre ones. I checked my alignment with them right after I got off the rack and it was spot on. Quote Link to comment Share on other sites More sharing options...
1slowspec3 Posted April 9, 2010 Author Share Posted April 9, 2010 nice find. but how do i read the inches/cm on tape into degrees ? max caster on plates would be back most setting right? Quote Link to comment Share on other sites More sharing options...
VaTechM3 Posted April 12, 2010 Share Posted April 12, 2010 don't you need radians or something awesome like that to make the conversion? pi/180? Man that has been a while. I'm sure google can do it for you though Quote Link to comment Share on other sites More sharing options...
matt325 Posted April 12, 2010 Share Posted April 12, 2010 nice find. but how do i read the inches/cm on tape into degrees ? The length of the toe plates (since you measure ahead of and behind the wheel) The difference between the two measurements The 'atan' function on you calculator total toe (degrees) = atan (difference measured by the tapes / length of the toe plate) There will be a very small error since the wheel diameter is what you really want to base the toe off of. I have simple spreadsheet that handles all the details. I'll be happy to send it to anyone that wants it. max caster on plates would be back most setting right? Yes, I believe that is correct. They are shipped in the max caster position, so unless someone messed around with them before installing, they should already be set. Quote Link to comment Share on other sites More sharing options...
