Listing this car for a friend who does not have much spare time to answer inquiries. He bought it to have a lower powered car (he also has a C6 corvette race car) to help improve his driving skills and is now ready to move on.
The car is professionally maintained and is ready to go.
photos can be found here:
http://picasaweb.google.com/claykos/BMWE30#
1991 BMW E30 with M50 motor
NASA PTC car with logbook; 2400 lb with fluids; 193 rwhp by dyno
Driveline:
1995 single VANOS M50 2.5L motor
motor rebuilt 2009; less then 6 hours after rebuild
Brand new VANOS unit from BMW
M3 cams
Stainless Headers (small dent in one of the headers)
Turner Motorsport Chip, fuel pressure regulator and fuel injectors
UUC under drive pulley
6 puck no spring clutch disk
M20 lightweight flywheel
1991 318i transmission
3.73 limited slip differential and Bimmerworld Differential Cooler in spare tire well
Accusump
M3 throttle position sensor
New starter; updated water pump
Ron Davis Radiator
Custom exhaust with Borla mufflers
Suspension:
Brand new Ground Control Koni coilover shocks/struts with one race weekend
ST sway bar with reinforcement brackets front and rear
Sparco strut tower brace
Reinforced shock mounts
Ireland Engineering toe and camber adjustment kit
New M3 steel control arms
New rack and pinion steering inner socket/tie rod assemblies with new lock plate and rack boot
Brakes:
25 mm master cylinder
Front: VW 11.5” rotor (from VW Corrado)
1993 Mazda RX-7 calipers
Rear: stock
Safety:
Full custom 6 point roll cage with rear shock tower tie-in; 3 nozzle fire suppression; IO Port seat brace; Window net and right sided net; Remote power off switch; Sparco removable steering wheel
Wheels and Tires:
2 sets 15 inch Rota Slip Stream
4 with Goodyear Eagle RS’s (about 6 heat cycles
4 with Hoosier R6’s with multiple heat cylces
Turnermotorsport Wheel studs
Other:
Lexan front and side windows; Sparco hood pin set and lightened hood; Front air dam and rear wing; 3 hours of track time on car since brakes flushed and filled with wilwood brake fluid, tranny/differential fluid changed and new brake pads; Car completely corner balanced with 200# driver; Arizona car with no rust. Differential Fan, Differential Pump, Engine Fan wired with dash mounted on/off switches.
Spares:
318 i tranny (has broken mount); M50 block; Hawk brake pads
Price: $13k or reasonable offers
Contact: [email protected]
