Enduro Car/parts for sale
SRC/SampsonRacingComm.
 Share
Sad but True, the Sampson Racing Communications E1/PTC race car is being parted out. We blew either side seals or apex seals at the last NASA race two weeks ago on the street ported 13b. Time to move on.
So heres the list, lots of goodies.
86 non sunroof tub with 8 point cage (NASA/SCCA legal) NASA logbook. Forward mounts go through firewall to shock towers. Includes pedals and master cylinders, complete steering system minus wheel, 24 gallon fuel safe fuel cell, radio harness, wiring, front and side glass, doors, fiber glass hood, fiber glass, rear fenders, stock front fenders, window net etc. NO Suspension $1,500 OBO
Early 13b street ported needs rebuild. Make offer
Rims 5x114.3x7 35MM offset Team Dynamic Motorsports 2 sets - $95 each or 8 for $700 (good condition) will fit 225-45-15 tires
*** Jericho 4 Speed Trans w/ 13b Mounting Plate (Trans in Perfect shape/ just serviced less than15 hrs ago) tall first gear, close ratio 2,3,4. Clutchless upshifts, very stout. Same stuff used in Nascar. $4000 - SOLD
Custom Drive Line (Jericho to rear FC RX7 Diff) x 2 - $300 each -SOLD
4 Puck Racing Clutch and Pressure Plate Like New condition (2 hours old) $100
Used Alternators x 2- $50 each
Pinned Distributor w/ cap, wires and Rotor -$75
FC Front Calipers w/ Blue Hawk Pads (50%) - $50
FC Rear Calipers w/ Black Hawk Pads (50%) - $50
FC Front Lower Control Arms (Rt and Lt work on both sides) $75 each
Tein Flex Coil Over Package w/ in car Shock Adjusting Computer (16 setting from soft to hard/front and rear) Complete - $1800 (Set-up for 2400lbs car) very trick
SS Braided Brake Lines (used full set) -$120
Racing Beat Header (20 hrs) -$150
Dual split Exhaust to stock location -$100
Racing cross flow Aluminum Radiator -$100
Down Draft 13b 4 port Intake for Weber Carb -$200
Weber 48 IDF Down Draft - $300 (some Jets as well)
5:10 rear end w/ Limited Slip/ Delron Subframe Bushings and Hyme adjuster for diff - Recent rebuild $300 SOLD
Front and rear hubs w/ extra brand new bearings -$100
Dash Parts w/ Tach/shift light/Oil temp/Oil Pressure/Water temp and EGT's -$375 SOLD
May separate if needed.
Will post pics soon. Email or PM with requests for pics or offers.
 Share
