GTS3 1998 M3
Posted (edited)
It kills me to do this, but responsibilities are responsibilities.:rolleyes
1998.5 M3. I have owned this car since 2002. I'm the second owner (since 29k miles) and have all records of service and modifications since I bought it. Converted to a TT car in 2007 (National Champion and track record!). Built out for GTS last year. Maintained by a pro shop (VFC Engineering).
Chassis and drivetrain have 93k miles. Motor is very strong, doesn't leak anything or make any bad sounds (not even lifter tick!). I have a clean Blackstone report from last oil change. Transmission and rear end work perfectly and make no sounds. Again, clean Blackstone reports from recent fluid changes. Body is solid with usual racing wear and tear. Rear end damage from off at Mid-O was pulled and fixed 3 years ago.
GTS3--dynos 248whp/235wtq and weighs 2600 lbs.
Parts list:
Engine/driveline
Stock 3.2, never opened
AA 3.5' intake
540 HFM
BW elbow
M50 (BW kit)
24lb injectors
Conforti software
AKG poly motor mounts
MCoupe radiator/Spal Fan
VDP oil cooler and cap
Raceland headers
Custom 3' exhaust (Borla muffler)
UUC ltw flywheel and M5 clutch (no slipping)
Short shift kit
All stock transmission and rear drive
Suspension:
TCK D/A coilovers
TCK Camber plates
Racing Dynamics bars
All metal bushings/bearings (TMS and BW)
Reinforced front subframe, rear pockets and rear sway bar tabs
Stock calipers/rotors
BW brake cooling ducts
2 sets of Kosei wheels
1 set of rims for rains
Body and aero:
CF hood
CF sunroof
Lexan 1/4 windows
LTW wing with risers (ebay)
Max Velocity Evo I track splitter
Safety:
8pt cage with NASCAR bars built by Izzy's Custom Cages
SPA 4L fire system
Schroth right side net
Sabelt 6-pt harnesses
Spares/xtras:
CF hood
OE rotors
SS brake lines
I think that's it. If you see something in the pics not mentioned above, don't assume its included, but please inquire as I may have just forgotten to list it.
This car is a solid and reliable car. I'm sad to see it go.
$23,500 Email: kburkhardt12 at comcast dot com
Updated pics soon, but for now:
What the wah? Come on, you didn't do that bad at Putnam.
Sorry to see you go, especially since you're a GTSer , good luck with the sale. I hope you plan on coming back in the future...
We'll get you in a 944 Spec car for 1/2 that. Then you can take care of at least 1/2 of your responsibilities .
Seriously, didn't see this coming - what a bummer!
GLWS in any case - it is a great car!
Why are you selling? Seems like you made some improvements over the winter and such. Just curious. Cheers.
No one said it was an easy decision. I'm just trying to keep my racing options open--maybe explore another project.
Gotcha. Well good luck with the sale! Cheers.
  • 2 weeks later...
sorry to see her go. are you staying german? are you taking offers or is you price firm?
  • 1 month later...
Do you still have this car? Will You be running it anwhere this summer/fall? do you have any additional photos?
