FS: 1985 Toyota Corolla GT-S
Posted (edited)
1985 TOYOTA COROLLA GTS
ENGINE
4AGE 20v Silvertop
SDS Stand Alone Engine Management
K&N Intake
Custom Header & Exhaust
Hi Capacity Radiator
ACT Stage1 Clutch
KAAZ 2-WAY LSD
TechnoToyTuning Short Shift Kit
Lightweight Battery
Spare Transmission
SUSPENSION
TRD Race Spring (8fr & 6rr)
Tokico HTS Dampers
Techno Toy Tuning Camber Plates, NRCA's, Panhard Bar, steering wheel spacer, & Rear 4-link
Brembo blank rotors
Project Titan Kai pads
Goodridge Stainless steel brake hoses
13x8 Rota R8
225/50-13 Hoosier A6
14x7 Konig Rewinds
195/60-14 Falken Ziex ZE-512
EXTERIOR
Electric Blue Paint
CFRP Hood & Hatch
Lexan rear window
JDM Kouki Bumper (fr&rr)
Sunroof delete (lexan)
APR CRFP side mirrors
INTERIOR
Full Roll Cage (NASA & SCCA legal)
Sparco Evo Seats (drv only)
Sparco 4pt harness (drv only)
Custom Seat Rails
Takata Seat Belt Pads
Roll Cage Padding
NEW
Calipers
Brake Master Cylinder
Clutch Slave Cylinder
Wheel Bearings
LSD Bearings
Tie Rod Ends (outer & inner)
This car has done it all. It is very competitive as an autoxr. I've also done well at regional drift competitions. I ran a 1:47 during my first HPDE at Mid-Ohio Sportscar Course. This car comes with a lot of extra parts. $5900 obo.
[email protected]
  • 1 month later...
Posted (edited)
New Price $5.9k
I've never taken it to the dyno. The stock 20valve 4age engine should make 160hp. This has intake, headers, and exhaust. That's probably worth 2hp?
Before the roll cage, it was just over 2000lbs. I'm not sure how much that added, but I'd assume under 100lbs, so under 2100lbs.
If the weight is super important, i can try to find some scales. LMK.
My GTS with the BT 20v weight 2280
And it was fully gutted
That's cool. There's more weight for mine to lose. Doors are still intact other than inner door panel. The rear glass is lexan, but the rear 1/4, doors, and windshield are still glass. Headlights are oem. That's a good bit of easy weight that could be taken out of mine.
  • 5 weeks later...
  • 2 months later...
