NASA ST2 Subaru
dunk
Selling my 2002 Subaru WRX built for NASA's ST2 class. Car is ready to race and equipped as follows. The below is just a summary of the specifications. I can answer detailed questions by phone or email. Car has run a 1:21 at Summit w/ dead tires (mediocre driver ) and is capable of going much faster.
Also looking for the following items which could be used as partial trade.
-05-07 STI
-Spec Miata
-Larger enclosed car trailer (24ft min) 28+ft preferred. Can be TAG or 5th Wheel
Engine (tuned for 350whp. Capable of more but ST2 rules limit power output)
-EJ257 block with Weisco pistons
-EJ20 heads with Kelford 272 cams, converted to shimless buckets
-Ported and coated factory manifold.
-Reverse Mounted intake manifold w/ custom intercooler piping
-Griffin aluminum radiator
-Hyperflow Front Mount Intercooler
-Mocal 19row oil cooler
-Mocal 13row 1/2 width power steering cooler included (not hooked up)
-Accusump
-Hydra Nemisis Engine Management
-FP Green with Tial 38mm wastegate
-Custom surge tank setup
Transmission
-2006 STI six speed with Spiider DCCD controller
-Driveshaft Shop aluminum driveshift
-R160 rear end with KAAZ LSD (spare diff included with car)
Suspension
-Koni DA shocks with Ground Control housings, camber plates front and rear
-Whiteline front and rear sway bars
-Aluminum front arms with Whiteline Roll Center adjusters
-Whiteline adjustable lateral links
-Every suspension bushing replaced
Brakes
-Custom Wilwoods W4A front calipers with 13.3x1.26 rotors (2 sets included)
-Wilwood dynalite rear calipers.
-Carbotech XP12 pads
-2 3" brake ducts to front wheels with water misters. Custom backing plates
Wheels
-17x10 CCW's. (2 sets included)
Chassis and Safety
-Widebody (2"), tubbed in front, with Piper Motorsports cage
-All glass replaced with lexan (front windshield MR10 with antifog)
-Custom frame rail brake ducts
-Momo halo seat, 6 point harnesses and window net
-Custom dash and rear firewall.
-Kognition 72" rear chassis mount wing
-Custom aluminum dash
-5 nozzle AFFF fire system
Spares Included
-One set of new rotors and front and rear brake pads
-Extra set of CCW wheels with 1/2 life NT01 tires
-Rear diff
-Front bearing
-Multiple custom wheel spacers (ranging from 3mm to 15mm)
-8" Springs (450lb, 550lb)
-Extra set of helpers
-Pressure tester for intercooler piping
-Belts, plugs, etc.
$25K. Offers accepted. Would prefer to sell the car as is so I don't have to part out.
thanks,
Duncan
Had some motor issues this last weekend so I'll probably be parting this car out. I'd take offers on the car without the motor though if someone wants a complete chassis ready for a powerplant.
-Duncan
