formula87 Posted May 27, 2010 Posted May 27, 2010 Up for Sale is a 1987 Pontiac Firebird Formula. Built to run in Nasa American Iron Racing series or may Run in SCCA American Sedan Have clear title Interior: Auto Power 6pnt cage Kirkey Deluxe Road race seat for driver (both seats have fixed mounting pos) Ultrashield Road Race seat for passenger G Force 6Pnt Camlock Harness for Driver and Passenger G Force Window net I-O Port seat back brace I-O Port Camera mount Engine: 355 Chevrolet. Forged FM pistons severe duty bearings, balanced rotating assembly. Polished rods. Trickflow Aluminum Heads with GM Aluminum Intake. SLP Jet hot Coated Headers Crane Roller cam with Comp Cams roller lifters and 1.7 roller tipped roller rockers. Moroso HV Oil pump and windage tray Moroso 7qrt Road Race Oil Pan Edelbrock Aluminum Water Pump. Holley mech 650 dual feed, MSD billet distributor w/ MSD 6AL box. Aluminum Catch cans for oil and water. Drivetrain: T56 6 speed Trans with GM Perf parts Flywheel and Centerforce Clutch GM factory 10bolt with Richmond 373 gear set Battery box located in trunk 4th gen Camaro SS 17” wheels with Z Rated tires w/3track days on them Suspension: Spohn performance: Wonder bar, Lower control arms, Panhard bar, Adjustable Torque Arm and trans crossmember with chrome moly spherical rod end mount. Polyurethane bushings on every suspension piece, motor mounts and trans mount. New tie rod ends, upper and lower ball joints, end links ect…… Fully adjustable Ground Control Suspension with weight jackers on all four corners 950lb springs front 175lb rear Koni yellow Dbl adjustable shocks and struts Baer 13” Brakes w/ braided lines and spindles. Owned since 1988 2nd owner. Was originally my Fathers car and I got it and drove all thru college. Then I wanted to go wheel to wheel but didn’t get there. Engine, Drivetrain, Suspension, since build has 40-50hrs on it and has seen only 4-5 track weekends in last 3-4years (since build) with NASA Mid Atlantic. I built the car and farmed out some of the engine and cage work. Please see pics...... It has passed thru Race tech at VIR and Summit Point. Has never been wheel to wheel. Passes Race tech with exception of interior safety net and cut off switch, which is included in sale. I have the ability to trailer to track and deliver within reason. Looking to get $18,000.00 but understand that seasoned racecars are going for less so I am willing to take offers. If you have any questions please email [email protected] , call 804-815-4257 or PM me or [email protected] . For more build pics and current pics and videos of car please see my photobucket site in my sig, or my youtube vid http://www.youtube.com/watch?v=enz4upxIsoM. Thanks for looking Quote
