Points for roll center correction?
If you were to add tall ball joints for roll center correction which points would you take?
7) Replace or modify control arms (other than plates, shims, slots, or eccentric bolts/bushings
for simple camber/caster adjustment only) or RWD/AWD rear trailing arms (may have
spherical/metallic joint for the connection to the spindle/knuckle) +4
8 ) Relocation of front suspension mounting points +6
16) Alteration of ball joints/dive angles +2
and for adding a rear pan hard and removing the stock Watt's link/Scott Russel assembly
17) Add panhard rod or Watt’s link (regardless of whether the Watt’s link replaces an OEM
panhard rod or not) +4
18) Replace or modify an OEM panhard rod or Watt’s link +2
  • National Staff
Not 18, it's 17. This is one that is waiting for the 2011 rules for clarification.
He is still adding a panhard rod.
