Balroks Posted June 11, 2010 Share Posted June 11, 2010 How are you guys running both? I've been running the cool shirt for about a year now, and damn it's great, especially when I was in FL. I just got the car back together this year and I just picked up my first fire suit back in March. While it was cool outside in April I didn't need the cool shirt and didn't think anything of it. Now that it's bloody hotter then hades, I'd like to wear it, but curious on how to provision it. Some people keep telling me to slit a hole in the fire suit for it, but that sounds retarded a moot. The fire suit obviously needs to be fully zipped up and worn properly, but the tubing for the shirt has no where to go. Curious on what others have done? Quote Link to comment Share on other sites More sharing options...
Sterling Doc Posted June 11, 2010 Share Posted June 11, 2010 Put a hole in the lining of the pocket, and run the tube through that and out the pocket. Quote Link to comment Share on other sites More sharing options...
Members Shawn M. Posted June 11, 2010 Members Share Posted June 11, 2010 Put a hole in the lining of the pocket, and run the tube through that and out the pocket. Meh, that just promotes pocket pool. On my suit, the zipper works on both ends. I upzip the bottom and stick the tubes thru there. You get used to the stares of the twin protruding tubes from your groin area flopping around as you walk around. (I usually either take off the suit or if time doesnt allow, I tuck the tubes back into my suit.) I wouldnt cut any holes in the suit if you can avoid it. Quote Link to comment Share on other sites More sharing options...
krystar Posted June 11, 2010 Share Posted June 11, 2010 why do you two have same superman avatar.... heheh Quote Link to comment Share on other sites More sharing options...
Members Shawn M. Posted June 11, 2010 Members Share Posted June 11, 2010 why do you two have same superman avatar.... heheh Thats the lame message boards way of saying we have posted alot. Means nothing. Quote Link to comment Share on other sites More sharing options...
Balroks Posted June 11, 2010 Author Share Posted June 11, 2010 Is there any passing tech to worry about with the pocket hole? Cause on the suit it's only the one zipper going up. Quote Link to comment Share on other sites More sharing options...
panozracing Posted June 11, 2010 Share Posted June 11, 2010 i cut a hole in the suit pocket...no problems with tech. Quote Link to comment Share on other sites More sharing options...
jrgordonsenior Posted June 11, 2010 Share Posted June 11, 2010 Some pro driver friends I know cut a slit under their left arm pit as that's where the tubes come together. They pull out about 12 inches of tubes which makes an easy connect/disconect.... Quote Link to comment Share on other sites More sharing options...
mbuskuhl Posted June 11, 2010 Share Posted June 11, 2010 i cut a hole in the suit pocket...no problems with tech. same here Quote Link to comment Share on other sites More sharing options...
Z06RACER Posted June 12, 2010 Share Posted June 12, 2010 i cut a hole in the suit pocket...no problems with tech. I cut a hole as well. I never thought about that being a problem. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted June 15, 2010 Share Posted June 15, 2010 I run mine out the bottom of the zipper on the suit... Quote Link to comment Share on other sites More sharing options...
Balroks Posted June 15, 2010 Author Share Posted June 15, 2010 I run mine out the bottom of the zipper on the suit... Tis what I ended up doing, found the second zipper and walked around with my "tubes hanging out" as shawn said, got a few laughs out of it Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted June 16, 2010 Share Posted June 16, 2010 don't forget your nomex undies if you go that route Quote Link to comment Share on other sites More sharing options...
