genikz Posted June 15, 2010 Posted June 15, 2010 For Sale: Enthusiast owned 1983 guards red Porsche 944, black interior. Professionally rebuilt motor (approximately 28k ago). Approximately 107k on chassis. Custom dash and interior. Price $4900 US OBO. Purchased a 928 as reason for selling. Also, car is set-up for aggressive driving on A/X or track car, but is very comfortable and drivable on the street. Drive to the track and drive home. Very reliable transportation. I would drive it anywhere and have. Drivetrain Motor: @78k, Complete Engine Rebuild (28,XXX mi. ago.) Included in rebuild: All seals, new rod and main bearings, cross-drilled and knife-edged and balanced crank, front seals, belts, headgasket, heads/valves re-worked with 5 angle cnc machine (all worked performed by Henry "Kurt" Tahmasian). Pan gasket replaced. All service up to date Oil changed (Mobil 1) changed 2100 mi ago Oil/filter changed every 3-4k with synthetic oil Waterpump replaced approx. 28k mi. ago Timing/Balance Belt approx 12k mi. ago Late DME/AFM for better throttle response MSDS header (6k ago) Custom exhaust w/high flow cat/muffler (stock available) At rebuild, parts replaced include new fuel pressure regulator and damper and vacuum lines. No leaks whatsoever 951 external oil cooler (internal unit prone to leaks replaced). Porsche 951 cooling fans (engine never rises above 195 degrees in the most aggressive environment/runs around 180 degrees in normal driving) Dist.rotor and ign. wires replaced (magnecor)(approximately 21k) Plugs have less than 4k (extra set included) Smog compliant AC Compressor delete K&N filter Extra DME relay included Transaxle: 944S (for sturdiness) with fresh synthetic oil (Redline). Transaxle has approximately 89k. Shifts are crisp with no grinding Complete clutch replaced right before engine rebuild, approximately 30k ago. Suspension/steering: Original manual steering rack with bushings replaced 28k ago All aluminum control/trailing arms installed from a low mileage 1986 Porsche 951 (944 turbo), early offset Front control ams (rebuilt 7k ago) with grease fittings (Paragon SD rebuild kit) Weltmeister poly bushings at the same time. Front coil overs (400lb Ground Control springs and perches) with Bilstein HD shocks (less than 5k on shocks and front suspension) Rear hollow 31mm torsion bars (effective rate 400lbs.) with Koni yellows (probably should be replaced with Bilstein HD as they were used at time of installation) Porsche 951S M030 26.8mm fr, 16mm rear sways. Fresh Weltmeister poly bushings all around. Front inner and outer wheel bearings replaced approximately 7k ago. Could use complete alignment and tire balancing as suspension work was done and no subsequent alignment. Tires need replacing Car comes with straight, "cookie-cutter", painted flat black. Extra set of cookies available with tired Hoosiers race tires mounted. Rims also painted flat black. Body: Straight body with fender bender dent in passenger side front fender near headlight. Car had fiberglass 951 nose at time of paint job (2006). Since then nose was replaces with stock and repainted unprofessionally (me). Front spoiler/valence has scuffs and could use replacement and or respray. Two straight front fenders, nose piece and hood included with sale. 931 hood (naca ducted) on car Stock European fiberglass bumper. Very expensive and hard to find part. Bolt holes where a 951 valence was mounted are present and could be easily filled and painted. Fog lights cracked and were removed for weight savings. Headlights are H 5 and work perfectly. Pop up and down seamlessly. Keyless entry Nice upgraded cargo cover. Interior: Custom leather sport seats Custom dash w/all new Autometer Sport Comp gauges (replaced 28k ago at time of engine rebuild), red LED lighting Center console has Autometer Sport Comp voltmeter, oil pressure and narrow band air/fuel gauge. All gauges work. Sparco 368 suede steering wheel High end billet aluminum quick release (Paragon Products) Shortened, custom stainless steel shift knob w/ replaced (15k) shift bushings and shaft. Dash has usual cracks, covered with custom aftermarket plastic cover. Not perfect, but looks fine. I am sure I am missing somethings, but this is a well cared for, well sorted 944 which will provide years of faithful and reliable driving and racing. Contact: Michael at jaffe.michael1 [at] gmail.com Quote
