rogue55 Posted June 22, 2010 Share Posted June 22, 2010 I have a 94 civic DX hatchback If I already have 92-95 Civic SI Hatchback parts installed on this car such as: Brakes (SI Knuckles,Rotors and Calipers both front and rear) Engine (D16z6 1.6L SOHC VTEC USDM) Suspension (front and rear sway bars, control arms and trailing arms) will I be able to use this car to compete in H4 (as though I had rebuilt an SI with a DX tub), or will I be forced to use this car in H2 since it has "upgraded" brakes and engine that weren't original to the trim level. Quote Link to comment Share on other sites More sharing options...
slammed_93_hatch Posted June 22, 2010 Share Posted June 22, 2010 what "SI brakes" are you talking about? If its the 94 Honda civic SI w/ABS SI then that is fine. If it is any other "SI brakes", then you will just have to change out the caliper to the 94 Honda civic SI w/ABS SI caliper. Quote Link to comment Share on other sites More sharing options...
rogue55 Posted June 23, 2010 Author Share Posted June 23, 2010 it has the brakes from a 94 civic Si with ABS. Front and rear discs all off the same car. Quote Link to comment Share on other sites More sharing options...
