tparm 0 Posted July 15, 2010 Share Posted July 15, 2010 Interior SOLD $250 Sparco EVO L seat (was passenger seat) with full hard-mount hardware SOLD $100 Sparco 3” harness with camlock (expires this year) SOLD $100 Schroth 3" harness with camlock (expires next year) $100 Master battery cut-off with full wiring harness $250 Full console with custom carbon insert with 2 mechanical switches (were for defrost and fan) $50 under-dash blower assembly for defrost with tubing Suspension SOLD $1,750 Full TC Kline “Smart” two way adjustable suspension with 700# rear and 500# front springs $250 TC Kline Xbrace SOLD $200 TC Kline adjustable rear lower control arms SOLD $100 Solid motor & transmission mounts SOLD $100 TC Kline rear upper shock mounts $100 Adjustable rear sway bar links SOLD $300 Turner Motorsports sways, f/r SALE PENDING $250 Ground Control adjustable tie rods (inner-outer) SOLD $650 Bimmerworld “Race” front control arms with Ground Control bushings (40 minutes of use) SOLD $250 Ground Control upper strut mounts & full-“race” camber/caster plates $350 pr OEM complete front spindle & hub assemblies A must for converting 325i to M3 components Brakes $250 OEM M/// rear rotors and calipers with almost new Hawk HT10 pads SALE PENDING $2,000 StopTech ST40 332x32mm complete front brake kit with almost new Hawk HT10 pads (40 minutes on whole system). Will throw in wheel spacers and lines below). Full set of Precision braided brake lines SOLD $100 Bimmerworld front brake cooling kit, partial (full kit except tubing and screws for air-dam mounts). Look like new. Wheels & tires SOLD $1,400 Full set (4) brand new “sticker” Hoosier R6s (245/40/17) mounted on SSR Comp (17x8) wheels SOLD $1,000 Full set (4) lightly used Hoosier full-rains mounted on Kosei wheels SOLD $125 per wheel. (3) good SSR Comp wheels as above Drivetrain $500 Remanufactured BMW Getrag 5 speed transmission. Was installed in 07 $800 Popular M5 clutch/UUC flywheel combo, light use Misc $200 Fiberglass trunk lid, in perfect shape, no mounting hardware, has holes drilled for Motorsport rear wing. I have rear wing assembly but it is cracked around the base over a 1/3 of the way around. $100 Euro tail light assemblies, no bulbs SOLD $1,000 Kromer Kraft custom headers and full exhaust Quote Link to post Share on other sites
