*EDIT* GTS3 e36 M3 parts for sale (@ VIR on 24th)
tparm
Interior
SOLD $250 Sparco EVO L seat (was passenger seat) with full hard-mount hardware
SOLD $100 Sparco 3” harness with camlock (expires this year)
SOLD $100 Schroth 3" harness with camlock (expires next year)
$100 Master battery cut-off with full wiring harness
$250 Full console with custom carbon insert with 2 mechanical switches (were for defrost and fan)
$50 under-dash blower assembly for defrost with tubing
Suspension
SOLD $1,750 Full TC Kline “Smart” two way adjustable suspension with 700# rear and 500# front springs
$250 TC Kline Xbrace
SOLD $200 TC Kline adjustable rear lower control arms
SOLD $100 Solid motor & transmission mounts
SOLD $100 TC Kline rear upper shock mounts
$100 Adjustable rear sway bar links
SOLD $300 Turner Motorsports sways, f/r
SALE PENDING $250 Ground Control adjustable tie rods (inner-outer)
SOLD $650 Bimmerworld “Race” front control arms with Ground Control bushings (40 minutes of use)
SOLD $250 Ground Control upper strut mounts & full-“race” camber/caster plates
$350 pr OEM complete front spindle & hub assemblies
A must for converting 325i to M3 components
Brakes
$250 OEM M/// rear rotors and calipers with almost new Hawk HT10 pads
SALE PENDING $2,000 StopTech ST40 332x32mm complete front brake kit with almost new Hawk HT10 pads (40 minutes on whole system). Will throw in wheel spacers and lines below).
Full set of Precision braided brake lines
SOLD $100 Bimmerworld front brake cooling kit, partial (full kit except tubing and screws for air-dam mounts). Look like new.
Wheels & tires
SOLD $1,400 Full set (4) brand new “sticker” Hoosier R6s (245/40/17) mounted on SSR Comp (17x8) wheels
SOLD $1,000 Full set (4) lightly used Hoosier full-rains mounted on Kosei wheels
SOLD $125 per wheel. (3) good SSR Comp wheels as above
Drivetrain
$500 Remanufactured BMW Getrag 5 speed transmission. Was installed in 07
$800 Popular M5 clutch/UUC flywheel combo, light use
Misc
$200 Fiberglass trunk lid, in perfect shape, no mounting hardware, has holes drilled for Motorsport rear wing. I have rear wing assembly but it is cracked around the base over a 1/3 of the way around.
$100 Euro tail light assemblies, no bulbs
SOLD $1,000 Kromer Kraft custom headers and full exhaust
