FS: 1997 BMW M3 - SOLD (Maryland)
blaketk676
THE CAR IS SOLD!
Cosmo Schwartz
174k Miles
5-speed
Maryland State Vehicle Inspection (passed)
Maryland State Emissions (passed)
INSTALLED BEFORE MY OWNERSHIP:
-Short Ram Intake
-Shark Injector Software (not 100%, but rev limiter is higher than factory and previous owner believed the owner before him installed it.)
INSTALLED 3 YEARS AGO:
-Powerflex Rear Trailing Arm Bushing Kit
-Powerflex Rear Subframe Mount Kit
-Rogue Engineering Rear Shock Mounts
-Goodridge Stainless Brakelines
-Performance Friction "New Z-Rated" Pads
-Solid Brake Guides (from Bimmerworld)
-Motul RBF 600 Brake Fluid (Flushed again June 2008)
-UUC EVO3 Short Shifter
-UUC DSSR
-UUC RK6A Shift Knob
-Replaced all shifter bushings with OEM
-Water Pump (metal impeller)
-Aluminum Thermostat Housing
-Thermostat - OEM
-BMW Anti-Freeze
-Upper and Lower Radiator Hoses
-Idler Pulley
-Belt Tensioners and Belts
-Interior AC Filter
INSTALLED 12-8 MONTHS AGO:
-New Headlight Assemblies
-SSI Stealth Underpanel
-Guibo (Flex Disc)
-Remanufactured driveshaft (replaceable u-joints, new center support bearing, purchased through Bimmerworld)
-Transmission Mounts
-Fan Clutch
-Power Steering Pump
-Power Steering Hoses
-Power Steering Rack
-Climate Control Panel
-AC Blower Motor
-Goodyear Eagle GT Tires (factory sizes)
-Factory Seat Belt Restraints (driver and passenger)
-Door Handle (old plastic broke, driver side, does not match factory key)
-Ignition cylinder (rolling tumbler syndrome, dealer ordered specific to my VIN, purchased a new key as well)
NEW PARTS OWNED, BUT NOT INSTALLED:
-Meyle HD Front Control Arms E36 96+ (from Bimmerworld)
-Powerflex Control Arm Bushings (offset, pressed into new housings)
-Replacement Coolant Expansion Tank (one on car is hard to see through due to its age)
PARTS OWNED, AND INCLUDED IF DESIRED:
-E36 Jacking Plate
-Peake Research BMW Airbag Scan/Reset Tool
-Peake Research BMW Oilservice Inspection Tool
-K&N Filter Cleaner Kit
-Sparco Torino 2 Seat (like new condition, black, no bracket/rails) +$200
  • 2 weeks later...
