Passing Technique ?
Lucid Moments
I moved up into HPDE3 back in December and am working on my off line driving. I do okay in a longer sweeping turn, but the shorter, tighter turns are eluding me so far. As a specific example I had a car point me by on the inside of turn 4 at VIR. In order for me to go inside I had to slow down so much that I couldn't get by him. How should I approach a turn like that?
I generally dont run with NASA, but in all other clubs, unless you are in advanced solo,
A. He should not be pointing you bye in a turn and
B. You should not take the pass in a turn, even with a point bye.
Just because someone points you by, does not mean you "must" take it.
I would not take the point by. If he gives you another one, on a straight, then go ahead. Otherwise, take a run through the pits. By the time you exit, he will be gone.
Better safe then sorry.
Just my opinion, fwiw.
PCA Instructor.
  • Members
You can always wave off the point-by or simply pull up next to them and stay side by side until you can pull away. One of the things we teach in the Competition License School is that two cars side by side are always slower than one in a section of track.
FYI - HPDE 3 is passing anywhere on track with a point-by highly recommended. It is a great preparation for drivers who move up to advanced driving and/or eventually go racing. Take any point-by that you feel comfortable and use it as a learning experience.
that may be something to practice solo - pretend there is a car to your outside in the tighter turns and practice carrying speed while leaving a lane
I thought about doing exactly that and will probably do it next time I drive. That way if I mess it up there are no boo boos to fix.
How about "Don't do this...":
After this past weekend, this is an area that I have identified to work on as well. I will be doing a lot of offline driving in practice and qualifying.
even if you had stuck it on the track (vs gravel trap) you just set yourself up for a classic "over-under"
NASA-MA allows passing anywhere on track with a point in the advanced/instructor groups (HPDE3 and HPDE4), FYI (for red00gt). With everyone working together, it is really a unique and enjoyable experience, and a fantastic learning tool for those looking to move onto racing.
Practicing off-line stuff solo is probably the smartest way to do it, but its also a little hard to judge your comparative speeds that way. For the most part, I always said, "F--- it, let's give this a shot" and paid VERY close attention to what the guy next to me was doing. When I give point-bys in corners, I treat this the same, and either stick to my side of the track until I see them go by, or watch for them to get behind me and wave it off. It comes down to cooperation and communication.
Another thought (if you can find/borrow a legal car), is to go to comp school, even if you aren't going wheel to wheel. You spend a lot of time working on these things there.
  • 2 weeks later...
Not every place is good for going 2 wide and making a pass. I can think of many places on the track I visit where it makes no sense to try to pass at all. It just slow you down too much. The except is if you have alot more grip and or power. Since I drive a momentum car I cannot lose momentum and expect to pass anyone. I don't have the HP to get the job done.
So first thing to learn/understand where the easy passing zone are on a track and what works for your car.
  • 2 weeks later...
Would there be fault in this pass? Incidental contact?
The front wheel of the second car had reached the door of the first before contact, so the second car had position.
Other than that ...
Other than that ...
Plus the passing car did have at least 2 wheels off at the time of contact...
Other than that ...
"3/4 car width"
