edhunter Posted July 30, 2010 Share Posted July 30, 2010 If a T5 will bolt up to a mod motor (not familiar with those requirements), you might look at these from Levy Racing. I run one, Levy has a shop just north of Charlotte. Any gear ratio you want, I think it uses Astro parts. Travis at Levy Racing East used to run Mid-South transmissions (or something like that) and built trannys for Nascar. He builds these T5's. I think the case is now the weak point as I run a stock case, but magnesium are available. No issues for the last year plus... Pricey but it should last w/ AI power levels... http://levyracing.com/store/levyracing-super-alloy-t5 Quote Link to comment Share on other sites More sharing options...
ST#97 Posted July 30, 2010 Share Posted July 30, 2010 If a T5 will bolt up to a mod motor (not familiar with those requirements), you might look at these from Levy Racing. I run one, Levy has a shop just north of Charlotte. Any gear ratio you want, I think it uses Astro parts. Travis at Levy Racing East used to run Mid-South transmissions (or something like that) and built trannys for Nascar. He builds these T5's. I think the case is now the weak point as I run a stock case, but magnesium are available. No issues for the last year plus... Pricey but it should last w/ AI power levels... http://levyracing.com/store/levyracing-super-alloy-t5 Takes a $250-300 SFI bellhousing from Quicktime, drill two holes for the crossmember and bolts right up with the same shifter on the T45. Very slick setup and the A5 parts from Astro are living well in several AI cars. David donovan runs one in his car and loves it. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted July 30, 2010 Share Posted July 30, 2010 T5s are junk imho. Wouldn't even run one in a street car if I could avoid it. Quote Link to comment Share on other sites More sharing options...
TurboShortBus Posted July 31, 2010 Share Posted July 31, 2010 I stumbled across this ad on Corner-Carvers, if anybody is looking for a T-56 for fairly cheap that needs some work. http://www.corner-carvers.com/forums/showthread.php?t=43669 I do not know the seller, and I have no interest in the sale. Mark EDIT: For those of you without a C-C account, here is the ad on the PBMC site: http://www.palmbeachmustangclub.com/pbmc/showthread.php?t=3443 Quote Link to comment Share on other sites More sharing options...
rtunney Posted August 4, 2010 Share Posted August 4, 2010 Jimmy, I am running the TKO 600RR in my 98 Cobra. A drastic improvement over the T45. The only complaint is, the shifter that came with the TKO is crap! Plan on getting something like a tr-iax etc. if you choose to go with the TKO. Rob Quote Link to comment Share on other sites More sharing options...
Red00gt Posted August 4, 2010 Share Posted August 4, 2010 I stumbled across this ad on Corner-Carvers, if anybody is looking for a T-56 for fairly cheap that needs some work. http://www.corner-carvers.com/forums/showthread.php?t=43669 I do not know the seller, and I have no interest in the sale. Mark EDIT: For those of you without a C-C account, here is the ad on the PBMC site: http://www.palmbeachmustangclub.com/pbmc/showthread.php?t=3443 Very reputable guy, but its been sold. Quote Link to comment Share on other sites More sharing options...
pederb Posted August 4, 2010 Share Posted August 4, 2010 A couple of guy here on the West Coast are using Richmond and they seam run w/o any problems. http://www.5speedtransmissions.com/5sp_comparison.html http://www.richmondgear.com/01fivespeed.html Cheers Quote Link to comment Share on other sites More sharing options...
brucebyerly Posted August 5, 2010 Share Posted August 5, 2010 A couple of guy here on the West Coast are using Richmond and they seam run w/o any problems.http://www.5speedtransmissions.com/5sp_comparison.html http://www.richmondgear.com/01fivespeed.html Cheers sonofabitch, now you tell us Quote Link to comment Share on other sites More sharing options...
ST#97 Posted August 5, 2010 Share Posted August 5, 2010 A couple of guy here on the West Coast are using Richmond and they seam run w/o any problems.http://www.5speedtransmissions.com/5sp_comparison.html http://www.richmondgear.com/01fivespeed.html Cheers No overdrive? Quote Link to comment Share on other sites More sharing options...
pederb Posted August 5, 2010 Share Posted August 5, 2010 A couple of guy here on the West Coast are using Richmond and they seam run w/o any problems.http://www.5speedtransmissions.com/5sp_comparison.html http://www.richmondgear.com/01fivespeed.html Cheers No overdrive? You can have them configured anyway you want Quote Link to comment Share on other sites More sharing options...
nape Posted August 5, 2010 Share Posted August 5, 2010 No overdrive? Overdrive is for people who run too low of a rear gear. Quote Link to comment Share on other sites More sharing options...
Mystic_Cobra Posted August 6, 2010 Author Share Posted August 6, 2010 FYI, I decided to go with a D&D T56 Magnum. Thanks for all the input. Quote Link to comment Share on other sites More sharing options...
ST#97 Posted August 6, 2010 Share Posted August 6, 2010 No overdrive? Overdrive is for people who run too low of a rear gear. I'm considering 4.10's actually!!! Quote Link to comment Share on other sites More sharing options...
King Matt Posted August 6, 2010 Share Posted August 6, 2010 No overdrive? Overdrive is for people who can't build an engine that spins high enough. Fixed that for you. Quote Link to comment Share on other sites More sharing options...
ST#97 Posted August 7, 2010 Share Posted August 7, 2010 No overdrive? Overdrive is for people who can't build an engine that spins high enough. Fixed that for you. 7k isn't enough?! Quote Link to comment Share on other sites More sharing options...
